HP EliteBook 725 G3 Lower Case Replacement
  1. HP EliteBook 725 G3 Lower Case Replacement, Lower Case: step 1, image 1 of 2 HP EliteBook 725 G3 Lower Case Replacement, Lower Case: step 1, image 2 of 2
    • Remove the ten 2.5 mm-long Phillips #0 screws securing the lower case.
  2. HP EliteBook 725 G3 Lower Case Replacement: step 2, image 1 of 2 HP EliteBook 725 G3 Lower Case Replacement: step 2, image 2 of 2
    • Use the pointed tip of a spudger to remove the rubber stoppers on the lower case.
  3. HP EliteBook 725 G3 Lower Case Replacement: step 3, image 1 of 3 HP EliteBook 725 G3 Lower Case Replacement: step 3, image 2 of 3 HP EliteBook 725 G3 Lower Case Replacement: step 3, image 3 of 3
    • Remove the remaining 2.5 mm-long Phillips screws that secure the lower case.
    • There should be 11 total 2.5 mm-long Phillips #0 screws when you're done.
    • Thelower has a click-release mechanism that is shown in the photos where the SD card is inserted.
    • Push in on this mechanism and remove the lower case.
Connor Bassolino
21,549 Reputation
98 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 20
