HP EliteBook 725 G3 Battery Replacement
  1. HP EliteBook 725 G3 Battery Replacement, Lower Case: step 1, image 1 of 2 HP EliteBook 725 G3 Battery Replacement, Lower Case: step 1, image 2 of 2
    • Remove the ten 2.5 mm-long Phillips #0 screws securing the lower case.
  2. HP EliteBook 725 G3 Battery Replacement: step 2, image 1 of 2 HP EliteBook 725 G3 Battery Replacement: step 2, image 2 of 2
    • Use the pointed tip of a spudger to remove the rubber stoppers on the lower case.
  3. HP EliteBook 725 G3 Battery Replacement: step 3, image 1 of 3 HP EliteBook 725 G3 Battery Replacement: step 3, image 2 of 3 HP EliteBook 725 G3 Battery Replacement: step 3, image 3 of 3
    • Remove the remaining 2.5 mm-long Phillips screws that secure the lower case.
    • There should be 11 total 2.5 mm-long Phillips #0 screws when you're done.
    • Thelower has a click-release mechanism that is shown in the photos where the SD card is inserted.
    • Push in on this mechanism and remove the lower case.
  4. HP EliteBook 725 G3 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the two 2.5 mm Phillips #00 screws securing the battery.
  5. HP EliteBook 725 G3 Battery Replacement: step 5, image 1 of 3 HP EliteBook 725 G3 Battery Replacement: step 5, image 2 of 3 HP EliteBook 725 G3 Battery Replacement: step 5, image 3 of 3
    • Lift and remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Owenbart
373 Reputation
4 Guides authored
UMass Dartmouth, Team 1-4, Botvin Fall 2025 Member of UMass Dartmouth, Team 1-4, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G4
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 99
