Introduction
This guide demonstrates how to access the I/O Board on the HP Chromebook x360 14-da0011dx. This will allow users to remove and replace the I/O Board in their device. Before dissembling device and replacing I/O Board check I/O ports for deck and debris which may be interfering with connection. I/O Ports may also have bent receptacles that can be adjusted to fix connections issues.
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
Locate the I/O Board on the top left of the laptop.
Remove the four 3.0 mm screws with the Phillips #1 screwdriver.
Flip up the ZIF connector locking flaps connected to the I/O board.
Remove the ribbon cables.
