Introduction
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Battery of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
Next, using the plastic opening tool remove the blue panel.
Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
Gently pry off the white back panel using the plastic opening tool.
