Introduction
The screen to the HP Chromebook 14a-ne0013dx is one of the most important and crucial components to the device’s functionality. The screen displays the graphics and visuals of the device. This guide should only be followed if sufficient or severe damage has occurred to the screen.
Remove two 8 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
Remove six 6 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
Flip the device over so it is right side up and open it.
Use a Jimmy to gently pry between the keyboard and case.
Pry gently to pop open the plastic tabs holding the top panel in. A clicking noise will occur during this step
Continue prying, moving around all sides of the panel until it is loose.
Carefully lift the top panel from the device body.
Peel the tape off of the cable connecting the battery to the motherboard.
Grasp the connector and tug until loose.
Turn the device so that the plastic hinge piece on the back is facing towards you.
Pry the edge of the plastic hinge piece until it comes out freely.
One at a time, pull the two pieces of black tape from under the bottom corners of the screen until they are fully removed.
