HP Chromebook 14a-ne0013dx Keyboard Panel Replacement
  1. HP Chromebook 14a-ne0013dx Keyboard Panel Replacement, Keyboard Panel: step 1, image 1 of 1
    • Remove two 8 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
    • Remove six 6 mm screws from the bottom panel of the laptop using a Phillips #0 screwdriver.
  2. HP Chromebook 14a-ne0013dx Keyboard Panel Replacement: step 2, image 1 of 2 HP Chromebook 14a-ne0013dx Keyboard Panel Replacement: step 2, image 2 of 2
    • Flip the device over so it is right side up and open it.
    • Use a Jimmy to gently pry between the keyboard and case.
    • Lift the top panel gently. Once loose, ribbon cables inside will need to be detached.
    • Pry gently to pop open the plastic tabs holding the top panel in. A clicking noise will occur during this step
    • Continue prying, moving around all sides of the panel until it is loose.
    • Carefully lift the top panel from the device body.
  3. HP Chromebook 14a-ne0013dx Keyboard Panel Replacement: step 3, image 1 of 2 HP Chromebook 14a-ne0013dx Keyboard Panel Replacement: step 3, image 2 of 2
    • Removal of ribbon cables may require lifting or peeling tape.
    • Lift the top piece of the display cable's housing until it is loose. Gently pull it free.
    • Lift the top piece of the touchpad cable's housing until it is loose. Gently pull it free.
    • With the cables detached, lift the front panel away from the device.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 21
All Time: 137
