Introduction
This guide walks through replacing the entire keyboard. If only certain keys need replacement, follow the note directly preceding removal of the full keyboard. The guide requires removing the keyboard mount. Afterwards, the process requires removing a lot of adhesive. This guide requires using a Phillips head screwdriver, a plastic opening tool, and tweezers to finish removal.
Flip the laptop upside down so that the lid lies flat on the table.
Remove the nine 6mm Phillips #00 screws that line the border.
Tilt the keyboard mount up.
Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
Gently remove both ribbon cables.
Flip the keyboard mount upside-down.
Using tweezers, peel off the two pieces of copper tape that keep the keyboard’s metal cover attached to the keyboard mount.
2 other people completed this guide.
One Comment
Is it possible to get a keyboard that lights up for the HP Chromebook 11 G3? If so then how?
