Introduction
If you find yourself needing to replace your HP Beats Special Edition 15-p390nr speakers this guide will show you step by step.
Turn computer over and begin removing noticeable 8mm screws with a Phillips #0 screwdriver.
Once screws are removed you may now remove the optical drive.
Remove the hidden 3mm screw in the optical drive port.
Remove the rubberized feet located on the left and right shoulder of the computer to uncover hidden 8mm screws.
The shoulder caps are removable. Underneath there are 2 additional screws.
