HP 17-x116dx Space bar key Replacement
  1. HP 17-x116dx Space bar key Replacement, Space Bar Key: step 1, image 1 of 1
    • Locate the spacebar key.
  2. HP 17-x116dx Space bar key Replacement: step 2, image 1 of 1
    • At the edge of the space bay key use a spudger to help with the removal.
  3. HP 17-x116dx Space bar key Replacement: step 3, image 1 of 1
    • Slide the spudger under the spacebar key.
  4. HP 17-x116dx Space bar key Replacement: step 4, image 1 of 1
    • The left side of the spacebar key will start lifting up. At this point you can remove the spacebar key.
  5. HP 17-x116dx Space bar key Replacement: step 5, image 1 of 1
    • During this point you can carefully take off the spacebar key.
  6. HP 17-x116dx Space bar key Replacement: step 6, image 1 of 1
    • you will notice a metal bars along the rim these metal bars is what connects the bottom surface together.
  7. HP 17-x116dx Space bar key Replacement: step 7, image 1 of 1
    • Dust off any dirt that could be under there.
  8. HP 17-x116dx Space bar key Replacement: step 8, image 1 of 1
    • The lower edge of the keyboard has two plastic notches on either side.
  9. HP 17-x116dx Space bar key Replacement: step 9, image 1 of 1
    • slide the bracket into the space below the spacebar to carefully place it back.
  10. HP 17-x116dx Space bar key Replacement: step 10, image 1 of 1
    • The Spacebar key will be working once you can press down and it will type a space.
Liliana Chuc
281 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 916
