Introduction
During the process, be careful with the placement of removed screws. This back panel disassembly is required to access all internal components.
Remove the four screws (13.7mm) with a Phillips #0 screwdriver.
Be sure to lift all four rubber tabs to access screws (7.51mm) underneath.
Use the Philips 0 screwdriver to unscrew the screws (7.51mm) that were underneath the battery.
