HP 15-fc0000 Series USB Board Replacement
  1. HP 15-fc0000 Series USB Board Replacement, Power off the laptop: step 1, image 1 of 1
    • Shut down the laptop.
    • Unplug the charger and any other cables from the laptop.
  2. HP 15-fc0000 Series USB Board Replacement, Remove the bottom cover screws: step 2, image 1 of 1
    • Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
    • Use a Phillips screwdriver to remove the four screws securing the bottom cover.
    • Two 6.8 mm‑long screws near the rear of the laptop.
    • Two 4.8 mm‑long screws near the front of the laptop.
  3. HP 15-fc0000 Series USB Board Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Release the bottom cover clips: step 3, image 2 of 2
    • The clips attached to the bottom cover are fragile. Use caution when releasing them.
    • Insert an opening pick under the bottom cover at the rear of the laptop.
    • Twist the pick until one or more clips release.
    • Repeat this procedure along the rear edge until you release all the clips.
  4. HP 15-fc0000 Series USB Board Replacement: step 4, image 1 of 2 HP 15-fc0000 Series USB Board Replacement: step 4, image 2 of 2
    • The bottom cover is fragile. Use caution when bending it.
    • Place your fingers under the part of the bottom cover you've raised, near a corner.
    • Use your fingers to gently pry up the corner of the bottom cover.
  5. HP 15-fc0000 Series USB Board Replacement: step 5, image 1 of 3 HP 15-fc0000 Series USB Board Replacement: step 5, image 2 of 3 HP 15-fc0000 Series USB Board Replacement: step 5, image 3 of 3
    • Insert an opening pick under the edge of the bottom cover next to the corner you've raised.
    • Pry up the back cover clips along the edge.
  6. HP 15-fc0000 Series USB Board Replacement: step 6, image 1 of 2 HP 15-fc0000 Series USB Board Replacement: step 6, image 2 of 2
    • Use an opening pick to repeat the procedure from the previous step to pry up the remaining sides of the bottom cover.
  7. HP 15-fc0000 Series USB Board Replacement, Remove the bottom cover: step 7, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Remove the bottom cover: step 7, image 2 of 2
    • Remove the bottom cover.
    • Some clips may re-engage when you're releasing other sides. If the bottom cover doesn't lift off easily, use the opening pick to release any remaining clips.
    • During reassembly, lay the bottom cover on the laptop so the sides of the cover align with the sides of the laptop. Then, gently press on the sides until you hear the clips click. If the clips don't engage easily, adjust the cover and try again.
  8. HP 15-fc0000 Series USB Board Replacement, Lift the speaker wire tape: step 8, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Lift the speaker wire tape: step 8, image 2 of 2
    • Do not put too much stress on the wire, as that can harm your laptop's audio quality.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
    • Try not to fold the tape so it can be reused during reassembly.
  9. HP 15-fc0000 Series USB Board Replacement, Move the speaker wires: step 9, image 1 of 3 HP 15-fc0000 Series USB Board Replacement, Move the speaker wires: step 9, image 2 of 3 HP 15-fc0000 Series USB Board Replacement, Move the speaker wires: step 9, image 3 of 3
    • Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
  10. HP 15-fc0000 Series USB Board Replacement, Remove the battery screws: step 10, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Remove the battery screws: step 10, image 2 of 2
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
    • During reassembly, press firmly on the battery connector to ensure a strong connection.
  11. HP 15-fc0000 Series USB Board Replacement, Remove the battery: step 11, image 1 of 3 HP 15-fc0000 Series USB Board Replacement, Remove the battery: step 11, image 2 of 3 HP 15-fc0000 Series USB Board Replacement, Remove the battery: step 11, image 3 of 3
    • Do not grab the battery at the ends because this battery is flexible. Instead, grab the battery one inch from each end to better support the middle.
    • Use two hands to grip the battery about one inch from each end.
    • Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
    • Pull the battery towards you to release it from its connector.
    • Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    • During reassembly, insert the battery onto its connector at a slight downward angle before pressing it flat to the frame.
  12. HP 15-fc0000 Series USB Board Replacement, Remove the right hinge screws: step 12, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Remove the right hinge screws: step 12, image 2 of 2
    • The right hinge is on the left side since the laptop is upside down
    • Use a Phillips screwdriver to remove the three 5.6 mm‑long screws securing the right hinge.
  13. HP 15-fc0000 Series USB Board Replacement, Open the right hinge: step 13, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Open the right hinge: step 13, image 2 of 2
    • Lift the left hinge to 90º so it's pointing upward.
  14. HP 15-fc0000 Series USB Board Replacement, Disconnect the USB board: step 14, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Disconnect the USB board: step 14, image 2 of 2
    • Use the flat end of a spudger to lift up the black locking tab on the USB board ZIF connector.
  15. HP 15-fc0000 Series USB Board Replacement: step 15, image 1 of 2 HP 15-fc0000 Series USB Board Replacement: step 15, image 2 of 2
    • Use tweezers or your fingers to grip the blue pull tab marked "DB."
    • Pull the ribbon cable away from its connector to disconnect it.
    • When reconnecting this cable, make sure the locking tab is fully open (up). The cable should slide in with minimal force. If you feel resistance, check that the locking tab is fully open and the cable is aligned, then try again.
  16. HP 15-fc0000 Series USB Board Replacement, Remove the USB board screws: step 16, image 1 of 2 HP 15-fc0000 Series USB Board Replacement, Remove the USB board screws: step 16, image 2 of 2
    • Use a Phillips screwdriver to remove the two screws securing the USB board.
    • One 3.1 mm‑long screw
    • One 4.3 mm‑long screw
  17. HP 15-fc0000 Series USB Board Replacement, Remove the USB board: step 17, image 1 of 3 HP 15-fc0000 Series USB Board Replacement, Remove the USB board: step 17, image 2 of 3 HP 15-fc0000 Series USB Board Replacement, Remove the USB board: step 17, image 3 of 3
    • Use your fingers to lift the right side of the USB board clear of the alignment post.
    • Remove the USB board by pulling it away from the side of the laptop.
    • During reassembly, insert the left side of the USB board into the opening in the side of the laptop first, then lower the right side onto the alignment pins.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Pennington
22,731 Reputation
123 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,757 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 233
