HP 15-fc0000 Series Motherboard Replacement
  1. HP 15-fc0000 Series Motherboard Replacement, Power off the laptop: step 1, image 1 of 1
    • Shut down the laptop.
    • Unplug the charger and any other cables from the laptop.
  2. HP 15-fc0000 Series Motherboard Replacement, Remove the bottom cover screws: step 2, image 1 of 1
    • Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
    • Use a Phillips screwdriver to remove the four screws securing the bottom cover.
    • Two 6.8 mm‑long screws near the rear of the laptop.
    • Two 4.8 mm‑long screws near the front of the laptop.
  3. HP 15-fc0000 Series Motherboard Replacement, Release the bottom cover clips: step 3, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Release the bottom cover clips: step 3, image 2 of 2
    • The clips attached to the bottom cover are fragile. Use caution when releasing them.
    • Insert an opening pick under the bottom cover at the rear of the laptop.
    • Twist the pick until one or more clips release.
    • Repeat this procedure along the rear edge until you release all the clips.
  4. HP 15-fc0000 Series Motherboard Replacement: step 4, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 4, image 2 of 2
    • The bottom cover is fragile. Use caution when bending it.
    • Place your fingers under the part of the bottom cover you've raised, near a corner.
    • Use your fingers to gently pry up the corner of the bottom cover.
  5. HP 15-fc0000 Series Motherboard Replacement: step 5, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement: step 5, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement: step 5, image 3 of 3
    • Insert an opening pick under the edge of the bottom cover next to the corner you've raised.
    • Pry up the back cover clips along the edge.
  6. HP 15-fc0000 Series Motherboard Replacement: step 6, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 6, image 2 of 2
    • Use an opening pick to repeat the procedure from the previous step to pry up the remaining sides of the bottom cover.
  7. HP 15-fc0000 Series Motherboard Replacement, Remove the bottom cover: step 7, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the bottom cover: step 7, image 2 of 2
    • Remove the bottom cover.
    • Some clips may re-engage when you're releasing other sides. If the bottom cover doesn't lift off easily, use the opening pick to release any remaining clips.
    • During reassembly, lay the bottom cover on the laptop so the sides of the cover align with the sides of the laptop. Then, gently press on the sides until you hear the clips click. If the clips don't engage easily, adjust the cover and try again.
  8. HP 15-fc0000 Series Motherboard Replacement, Lift the speaker wire tape: step 8, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Lift the speaker wire tape: step 8, image 2 of 2
    • Do not put too much stress on the wire, as that can harm your laptop's audio quality.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
    • Try not to fold the tape so it can be reused during reassembly.
  9. HP 15-fc0000 Series Motherboard Replacement, Move the speaker wires: step 9, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement, Move the speaker wires: step 9, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement, Move the speaker wires: step 9, image 3 of 3
    • Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
  10. HP 15-fc0000 Series Motherboard Replacement, Remove the battery screws: step 10, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the battery screws: step 10, image 2 of 2
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
    • During reassembly, press firmly on the battery connector to ensure a strong connection.
  11. HP 15-fc0000 Series Motherboard Replacement, Remove the battery: step 11, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement, Remove the battery: step 11, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement, Remove the battery: step 11, image 3 of 3
    • Do not grab the battery at the ends because this battery is flexible. Instead, grab the battery one inch from each end to better support the middle.
    • Use two hands to grip the battery about one inch from each end.
    • Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
    • Pull the battery towards you to release it from its connector.
    • Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    • During reassembly, insert the battery onto its connector at a slight downward angle before pressing it flat to the frame.
  12. HP 15-fc0000 Series Motherboard Replacement, Remove the plastic cover: step 12, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the plastic cover: step 12, image 2 of 2
    • Use tweezers to remove the plastic cover on the wireless LAN card antenna cable.
    • Set the plastic cover aside with the sticky side up.
    • Keep the adhesive on the back of the plastic cover clean, as you will reuse this during reassembly.
  13. HP 15-fc0000 Series Motherboard Replacement, Disconnect the antenna: step 13, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the antenna: step 13, image 2 of 2
    • Place one arm of a pair of tweezers under the metal head of the antenna cable. Lightly grip the head.
    • The pictured laptop only has one antenna cable, but yours may have two.
    • Lift straight up to disconnect the antenna.
    • It's important to lift the connector straight up. If lifted at an angle, you risk breaking the socket off of the board underneath.
    • Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
    • Don't try to force the connector into place or you may permanently damage it.
  14. HP 15-fc0000 Series Motherboard Replacement, Remove the wireless LAN card screw: step 14, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement, Remove the wireless LAN card screw: step 14, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement, Remove the wireless LAN card screw: step 14, image 3 of 3
    • Use a Phillips screwdriver to remove the 3.1 mm‑long screw securing the wireless LAN card.
    • The wireless LAN card will spring up at an angle after the screw is removed.
  15. HP 15-fc0000 Series Motherboard Replacement, Remove the wireless LAN card: step 15, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the wireless LAN card: step 15, image 2 of 2
    • Grip the wireless LAN card by its edges and pull it away from its socket to remove it.
    • During reassembly, insert the card into its socket at an angle before pressing it flat to the laptop.
  16. HP 15-fc0000 Series Motherboard Replacement, Remove the heat sink screws: step 16, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the heat sink screws: step 16, image 2 of 2
    • Use a Phillips screwdriver to remove the four 3.1 mm‑long screws securing the heat sink in the following order:
    • Top‑left
    • Bottom‑right
    • Bottom‑left
    • Top‑right
    • When replacing the screws, insert them in the same order as they were removed, i.e., top-left should be first.
  17. HP 15-fc0000 Series Motherboard Replacement, Remove the heat sink: step 17, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the heat sink: step 17, image 2 of 2
    • Lift the heat sink away from the motherboard to separate the thermal paste and remove it.
    • If the heat sink is stuck, gently wiggle it until it comes loose. If it's still stuck, use the flat end of a spudger to gently pry the heat sink off of the processor.
    • Do not pry on the processor with any metal tools.
    • To replace your thermal paste, follow this guide.
  18. HP 15-fc0000 Series Motherboard Replacement, Remove the SSD screw: step 18, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the SSD screw: step 18, image 2 of 2
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the SSD.
  19. HP 15-fc0000 Series Motherboard Replacement, Remove the SSD: step 19, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the SSD: step 19, image 2 of 2
    • Lift the edge of the SSD near the screw indent to a shallow angle.
  20. HP 15-fc0000 Series Motherboard Replacement: step 20, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 20, image 2 of 2
    • Grip the SSD by its edges and pull it away from its socket to remove it.
    • During reassembly, insert the SSD into its socket at a shallow angle before lowering it flat to the laptop.
  21. HP 15-fc0000 Series Motherboard Replacement, Remove the bracket screws: step 21, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the bracket screws: step 21, image 2 of 2
    • Use a Phillips screwdriver to remove the two screws securing the USB-C port bracket.
    • One 3.1 mm‑long screw
    • One 4.3 mm‑long screw
  22. HP 15-fc0000 Series Motherboard Replacement, Remove the metal bracket: step 22, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the metal bracket: step 22, image 2 of 2
    • Use tweezers or your fingers to lift the bracket off the USB-C port and remove it.
  23. HP 15-fc0000 Series Motherboard Replacement, Disconnect the motherboard: step 23, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the motherboard: step 23, image 2 of 2
    • The next ten steps instruct how to disconnect each connector on the motherboard. Refer to the Recognizing and Disconnecting Cable Connectors guide for more help.
    • DC‑in
    • Fan
    • Display
    • Speakers
    • Trackpad
    • Keyboard
    • Make sure all cables and wires connected to the top of the motherboard are disconnected before lifting the motherboard. Depending on the configuration of your laptop, you may have a different number of connectors to disconnect.
  24. HP 15-fc0000 Series Motherboard Replacement, Disconnect the DC-in cable: step 24, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement, Disconnect the DC-in cable: step 24, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement, Disconnect the DC-in cable: step 24, image 3 of 3
    • Use a spudger to "walk" the DC‑in cable out of its socket on the system board by pushing on alternating sides of the white connector.
  25. HP 15-fc0000 Series Motherboard Replacement: step 25, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 25, image 2 of 2
    • Once the cable is loose, use a spudger to push the DC‑in cable out of its socket on the system board.
  26. HP 15-fc0000 Series Motherboard Replacement, Disconnect the fan: step 26, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the fan: step 26, image 2 of 2
    • Insert one arm of blunt nose tweezers under the fan cable, as close to the connector as possible.
    • Grip the wires evenly and lift the cable up to disconnect the fan.
    • To reconnect the fan to the motherboard, use a pair of tweezers to grip all of the wires and align the connector with the socket. Then, use the flat end of a spudger or your finger to evenly press the connector into the socket.
  27. HP 15-fc0000 Series Motherboard Replacement, Disconnect the display: step 27, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the display: step 27, image 2 of 2
    • Use the flat end of a spudger to lift up the black locking tab on the USB Board ZIF connector.
  28. HP 15-fc0000 Series Motherboard Replacement: step 28, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 28, image 2 of 2
    • Use tweezers or your fingers to grip the black taped portion of the display cable.
    • Pull the ribbon cable away from its connector to disconnect it.
    • When reconnecting this cable, make sure the locking tab is fully open (up). The cable should slide in with minimal force. If you feel resistance, check that the locking tab is fully open and the cable is aligned, then try again.
  29. HP 15-fc0000 Series Motherboard Replacement, Disconnect the speakers: step 29, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the speakers: step 29, image 2 of 2
    • Insert one arm of blunt nose tweezers under the speaker cable, as close to the connector as possible.
    • To reconnect the speakers to the motherboard, use a pair of tweezers to grip all of the wires and align the connector with the socket. Then, use the flat end of a spudger to evenly press the connector into the socket.
  30. HP 15-fc0000 Series Motherboard Replacement, Disconnect the trackpad: step 30, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the trackpad: step 30, image 2 of 2
    • Use the flat end of a spudger to lift up the black locking tab on the trackpad ZIF connector.
  31. HP 15-fc0000 Series Motherboard Replacement: step 31, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 31, image 2 of 2
    • Use tweezers or your fingers to grip the blue pull tab marked "MB."
  32. HP 15-fc0000 Series Motherboard Replacement, Disconnect the keyboard: step 32, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the keyboard: step 32, image 2 of 2
    • Use the flat end of a spudger to lift up the black locking tab on the keyboard ZIF connector.
  33. HP 15-fc0000 Series Motherboard Replacement: step 33, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 33, image 2 of 2
    • Use tweezers or your fingers to grip the blue pull tab on top of the display ribbon cable.
  34. HP 15-fc0000 Series Motherboard Replacement, Remove the motherboard screws: step 34, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Remove the motherboard screws: step 34, image 2 of 2
    • Use a Phillips screwdriver to remove the seven 3.1 mm‑long screws securing the motherboard.
  35. HP 15-fc0000 Series Motherboard Replacement, Slide the motherboard out of its slot: step 35, image 1 of 3 HP 15-fc0000 Series Motherboard Replacement, Slide the motherboard out of its slot: step 35, image 2 of 3 HP 15-fc0000 Series Motherboard Replacement, Slide the motherboard out of its slot: step 35, image 3 of 3
    • Make sure all cables are disconnected from the top of the motherboard. Your laptop may have more cables than those listed here.
    • Remove the motherboard from its slot in the frame by lifting the left edge.
    • Pull the motherboard to the left and guide the external ports out of their slots.
    • The USB-A board cable is still attached to the back of the board, so don't try to remove the board entirely yet.
  36. HP 15-fc0000 Series Motherboard Replacement, Flip the motherboard: step 36, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Flip the motherboard: step 36, image 2 of 2
    • Flip the motherboard over and gently lay it on the laptop so you can access the remaining cable connector.
  37. HP 15-fc0000 Series Motherboard Replacement, Disconnect the USB board: step 37, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement, Disconnect the USB board: step 37, image 2 of 2
    • On the back of the motherboard (now facing up), use the flat end of a spudger to pry up the black locking tab on the USB board ZIF connector on the motherboard.
  38. HP 15-fc0000 Series Motherboard Replacement: step 38, image 1 of 2 HP 15-fc0000 Series Motherboard Replacement: step 38, image 2 of 2
  39. HP 15-fc0000 Series Motherboard Replacement, Remove the motherboard: step 39, image 1 of 1
    • Make sure all cables are disconnected from both sides of the motherboard. Your laptop may have more cables than those listed here.
    • Remove the motherboard.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
3 other people completed this guide.
Spencer Pennington
22,731 Reputation
123 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,757 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 799
