Introduction
Use this guide to replace the fan in your HP 15-fc0000 series laptop.
Note: This procedure was written using a model 15-fc0093dx HP 15 Laptop PC but is compatible with any HP 15 Laptop PC whose model number starts with 15-fc.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Shut down the laptop.
Unplug the charger and any other cables from the laptop.
Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
Use a Phillips screwdriver to remove the four screws securing the bottom cover.
Two 6.8 mm‑long screws near the rear of the laptop.
Two 4.8 mm‑long screws near the front of the laptop.
Insert an opening pick under the bottom cover at the rear of the laptop.
Twist the pick until one or more clips release.
Repeat this procedure along the rear edge until you release all the clips.
Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
Use two hands to grip the battery about one inch from each end.
Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
Pull the battery towards you to release it from its connector.
Use tweezers to remove the plastic cover on the wireless LAN card antenna cable.
Set the plastic cover aside with the sticky side up.
Place one arm of a pair of tweezers under the metal head of the antenna cable. Lightly grip the head.
Lift straight up to disconnect the antenna.
Use tweezers, a spudger, or fingers to lift the wireless LAN antenna out of the routing clips beside the fan.
Use a spudger to "walk" the DC‑in cable out of its socket on the motherboard by pushing on alternating sides of the white connector.
Use tweezers, a spudger, or fingers to lift the DC‑in cable out of the routing clips beside the fan.
Insert one arm of blunt nose tweezers under the fan cable, as close to the connector as possible.
Grip the wires evenly and lift the cable up to disconnect the fan.
Use a Phillips screwdriver to remove the three 4.3 mm‑long screws securing the fan.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
