HP 14-dq5043cl Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
117
All Time:
1,267
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Does your HP 14-dq5043cl struggle to power on, hold a charge for long periods of time, or die randomly? If that's the case, you may have a faulty battery that is in need of a replacement.
A laptop battery is one of the primary components responsible for providing power to the device. If compromised your device will not be operable. Our goal is to provide a comfortable and simple experience to replace this essential part.
Before you begin make sure your device is powered off and not plugged in.
Parts
Tools
  • Phillips #1 Screwdriver
    5
  • Spudger
    4.9
    1. HP 14-dq5043cl Battery Replacement, Lower Case: step 1, image 1 of 2 HP 14-dq5043cl Battery Replacement, Lower Case: step 1, image 2 of 2
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      Ask FixBot
    2. HP 14-dq5043cl Battery Replacement: step 2, image 1 of 1
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      Ask FixBot
    3. HP 14-dq5043cl Battery Replacement: step 3, image 1 of 3 HP 14-dq5043cl Battery Replacement: step 3, image 2 of 3 HP 14-dq5043cl Battery Replacement: step 3, image 3 of 3
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      Ask FixBot
    1. HP 14-dq5043cl Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the four Phillips screws that secure the battery.
      Ask FixBot
    2. HP 14-dq5043cl Battery Replacement: step 5, image 1 of 1
      • Grip the lower edge of the battery and pull it toward you to disconnect the blade-style battery connector.
      • Remove the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 other people completed this guide.
Tristan Virgo
585 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 117
All Time: 1,267
