HMDX Jam Plus Battery Replacement
  1. HMDX Jam Plus Battery Replacement, Battery: step 1, image 1 of 3 HMDX Jam Plus Battery Replacement, Battery: step 1, image 2 of 3 HMDX Jam Plus Battery Replacement, Battery: step 1, image 3 of 3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus Battery Replacement: step 2, image 1 of 2 HMDX Jam Plus Battery Replacement: step 2, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus Battery Replacement: step 3, image 1 of 2 HMDX Jam Plus Battery Replacement: step 3, image 2 of 2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus Battery Replacement: step 4, image 1 of 3 HMDX Jam Plus Battery Replacement: step 4, image 2 of 3 HMDX Jam Plus Battery Replacement: step 4, image 3 of 3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus Battery Replacement: step 5, image 1 of 3 HMDX Jam Plus Battery Replacement: step 5, image 2 of 3 HMDX Jam Plus Battery Replacement: step 5, image 3 of 3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus Battery Replacement: step 6, image 1 of 2 HMDX Jam Plus Battery Replacement: step 6, image 2 of 2
    • Use new adhesive to secure battery back to the rest of the device.
4 other people completed this guide.
Maxwell Erickson
587 Reputation
4 Guides authored
Montana Tech, Team 10-3, Shirk Fall 2015 Member of Montana Tech, Team 10-3, Shirk Fall 2015
MTUM-SHIRK-F15S10G3
4 Members
4 Guides authored
5 Comments
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - Reply
Where to purchase battery for hmdx jam speaker
Frank David -
Where can a battery be purchased?
robertwacker - Reply
What kind (especifications) that battery?
vecchio.farias - Reply
Where to buy battery for HMDX JAM.Bluetooth speaker
Frank David - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 7,098
