Introduction
Follow this guide to replace the charging board in your HMD Skyline Business Edition smartphone.
The USB-C charging port and storage expansion/SIM tray are attached to the charging board. If the USB‑C port breaks, you have problems charging your phone, or the SIM tray isn't inserting correctly, you'll need to replace the entire charging board.
Unplug all cables and completely power off your phone.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM tray hole on the bottom edge of your phone until the tray ejects.
Remove the SIM card tray.
With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
There's a seam just under the back cover panel. Don't insert your tool here.
Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
Lift and remove the back cover.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Make sure you remove all liners from the underside.
Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
Use a T3 Torx screwdriver to remove the two screws securing the battery connector cover.
Insert the tip of an opening pick under the top edge of the battery press connector and pry up to disconnect it.
Check if the rear camera press connector got disconnected during the previous step. If it did, reconnect it.
Use a T3 Torx screwdriver to remove the seven screws securing the loudspeaker:
Four 3.9 mm‑long screws
Three 4.9 mm‑long screws
Slide an arm of a pair of angled tweezers under the metal neck of one of the antenna connectors on the charging board and lift straight up to disconnect it.
Repeat the process to disconnect the other coaxial connector.
Hold the metal neck of the antenna connector with a pair of tweezers and align the head over its socket on the board.
Use the flat end of a spudger to press straight down on the connector head—it should snap into place. If you're having trouble, reposition the head and try again. Don't try to force the connector into place, or you risk damaging the charging board.
Slide an arm of a pair of angled tweezers under the top right corner of the charging board and pry up to release the clip on the top edge.
Lift the top edge of the board and remove it.
Make sure your USB‑C port has a rubber gasket around it. If it doesn't, transfer the gasket from your old board, making sure the side with a cutout goes on the bottom.
Insert the board at a downward angle so the USB‑C port goes into its cutout.
Press down on the top edge of the board to engage its clip.
