OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Use this guide to replace a dead or worn-out battery in your HMD Fusion Business phone.
Your phone's lithium-ion battery has a limited lifespan. If your phone dies quickly and doesn't hold a charge, it may be time to replace the battery.
If your battery is swollen, take appropriate precautions.
Unplug all cables from your phone and completely power it down.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
Use your fingernails, or angled tweezers, to remove any stuck screws.
Flip your phone over so the screen is facing up.
Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
Use a spudger to pry up and disconnect the battery press connector.
Use a spudger to pry up and disconnect the power button press connector.
Remove the back cover.
Use your fingers to carefully peel the three plastic tabs from the right side of the battery.
Use tweezers, or your fingers, to peel the three battery adhesive strips off the frame.
Align the new battery adhesive over the frame, making sure that the three adhesive strips overlap properly.
While holding the battery over its recess, temporarily reconnect the battery connector.
Lay the battery into its recess.
To reassemble your device, follow these instructions in reverse order starting with this step.
For optimal performance, calibrate your newly installed battery after reassembling your phone.
