ProtoCentre 999 Heater Replacement
    • Remove the back cover of the machine.
    • Remove the heater pin from the back side of machine.
    • Remove the groove screw from the downside of nozzle.
    • Preheat the machine
    • After getting preheated, pull slowly the wires of the heater back. and remove the nozzle out.
    • Reset the machine.
    • After the temperature get down full, preheat the machine
    • After 30 second check the heater is getting heated or not by slowing touch and removing your hand fastly
    • If it is not getting heating, you has to change the heater.
    • First remove the heater from the wire by desoldering.
    • Take the multimeter and put it in continuity check mode and connect the two end of the wire in end of two probe of multimeter.
    • Check whether the beep sound is coming. If the beep sound come, it means the wire is good , else you has to change the wires. Same way check the other wire also.
    • After checking these, you has to reconnect the heater in the same way you have removed before.
    • Go back to main menu
    • check the nozzle temperature is increasing or not.
abhishek j
1,169 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 549
