This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
If the machine is already working, proceed to step 3; if you need to check the lever locking electromagnet, stay here.
We will follow these steps if the machine still does not latch while heating when the lever is lowered. The first thing we will have checked BEFORE disassembling it is that when lowering and holding the lever, the nichrome wire turns red hot; if it does, the wire is okay, and we will rule out that part, moving directly to checking the electromagnet.
If the nichrome wire does not turn red hot when the lever is lowered, we have a broken nichrome wire or scorched contacts, as we saw in guide step 2.
To check the electromagnet coil, we have already removed its connector from the PCB during disassembly, so we can measure in the ohms range. The indicative measurement it gives us is approximately 134 Ohms; for a machine operating at 230 V AC, the coil is okay.
Having checked the electromagnet, we will now check the nichrome wire installed on 3 mica sheets (left, center, and right), so it is nothing more than a series circuit of 2 resistances (the nichrome wire is a resistive wire; its resistance increases every few centimeters).
Photo 1: We will take this as the input point of the resistance; at this point, we will place a multimeter test lead. We will place the other test lead on the back where we can see several output contacts coming out, checking that we have a resistance value.
Photo 2: On this machine, the fault was not the nichrome wire, so I barely spent time on this since it was working.
To close the machine, we will reconnect the 2 white connectors on the PCB; since they are different sizes, there is no doubt where they go, and we will reconnect the 2 yellow grounding faston connectors.
Insert the lever and test the toaster.
End of Guide 3.
All guides in this series: FIRST FA5367-1 (XB8133) Tostadora
