Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
63
All Time:
184
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Easy
    1. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising., Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 1, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising., Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 1, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising., Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 1, image 3 of 3
      • Continuation of Guide 1, Teardown. In this Guide 2, we see the issue with this toaster: the side guides deform very easily. We will straighten the guides using flat-nose pliers.
      Ask FixBot
    2. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 2, image 1 of 1
      • Using needle-nose pliers, carefully check the movement and straighten any mobile parts you observe.
      Ask FixBot
    3. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 3, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 3, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 3, image 3 of 3
      • If the machine does not latch when you lower the lever, one of the things to check is the cleanliness of the electromagnet; its three upper air gaps must be clean and shiny. It is also important to clean the metal plate that connects to the top of the magnet when you lower the lever.
      • You can clean the three upper parts of the electromagnet with a paper towel and alcohol.
      Ask FixBot
    4. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 4, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 4, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 4, image 3 of 3
      • We will test the movement the lever makes when lowering and "closing" the electromagnet from the top.
      Ask FixBot
    5. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 5, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 5, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 5, image 3 of 3
      • The other point to check if the lever does not lock when pushed down is the cleanliness of the 4 contacts that close when the lever is lowered; because the contact metal operates with mains voltage, it gets scorched and pitted, creating an insulating layer that prevents electrical continuity.
      Ask FixBot
    6. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 6, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 6, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 6, image 3 of 3
      • To clean the contact points, we will use a nail file, which is very useful for this repair. Remove the plate from the support by loosening the 2 screws that secure it, and with the plate removed, cleaning the contacts or contact points will be much easier.
      Ask FixBot
    7. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 7, image 1 of 2 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 7, image 2 of 2
      • Once an initial cleaning is done, cover the electrical contact with your finger to level both surfaces with the file.
      Ask FixBot
    8. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 8, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 8, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 8, image 3 of 3
      • Perform the same cleaning on the other pair of contacts; it does not matter if they are completely shiny, but it is necessary to remove the black layer that forms during operation.
      Ask FixBot
    9. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 9, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 9, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 9, image 3 of 3
      • Once the breaker points (contacts) are clean, lower and raise the lever several times to check the travel and clean it with a paper towel and alcohol.
      Ask FixBot
    10. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 10, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 10, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 10, image 3 of 3
      • Reinsert the PCB by aligning it with the 2 guides and secure it with the 2 screws.
      Ask FixBot
    11. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 11, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 11, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 11, image 3 of 3
      • Clean the stainless steel guide rail and the plate covering the electromagnet with alcohol (if you haven't already cleaned it in step 3), then test by raising and lowering it to ensure the travel is smoother.
      Ask FixBot
    12. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 12, image 1 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 12, image 2 of 3 Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 12, image 3 of 3
      • Lubricate the stainless steel guide with petroleum jelly.
      Ask FixBot
    13. Guide 2: FIRST FA5367-1 Toaster Lever jamming when lowering and raising.: step 13, image 1 of 1
      • We apply grease to the top and use our finger to spread the petroleum jelly over the entire stainless steel guide.
      • Once the cleaning, guide straightening, and lubrication work is finished, we move on to guide 3, where we can see some checks to perform in case we have a breakdown in the toaster. We will see how to check the electromagnet.
      • Guides in this series: FIRST FA5367-1 (XB8133) Tostadora
      • END of Guide 2.
      Ask FixBot
Carlos López (España - Spain)
108,553 Reputation
402 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 63
All Time: 184
