Introduction
If you have just bought your skateboard deck, strip the plastic from it and remove any stickers that are on the top of the deck where the grip tape will be applied. Be sure to have all of your tools and materials close by to make the installation process faster and more efficient.
Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 other people completed this guide.
