Google Pixel 5 Motherboard Replacement
  1. Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 1 of 3 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 2 of 3 Google Pixel 5 Motherboard Replacement, Eject the SIM card tray: step 1, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • The SIM card tray is located on the left edge of the phone near the bottom.
    • Press firmly to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Google Pixel 5 Motherboard Replacement, Heat the bottom edge of the screen: step 2, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the screen for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    It would be helpful to know for how long ally the heated pad
    Yuri Deglin - Reply
    Agreed, my friend from the past.
    Albert Einstein -
    If you click on the "iOpener" link, it tells you to heat it up for 30 seconds, and if you're using a microwave with a carousel, make sure it moves freely.
    Azurina Schalk-Smith - Reply
    How long do you think it would take with a hair dryer?
    Gen L. - Reply
  3. Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 1 of 3 Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 2 of 3 Google Pixel 5 Motherboard Replacement, Screen removal information: step 3, image 3 of 3
    • While you're waiting for the adhesive to loosen, take note of the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    Please remove the image of the pick in the bottom of the phone in Step 2. This led me to place a pick there BEFORE step 5 which damaged my digitizer. Now I have to replace the entire screen as a result.
    Alternatively, add the image from step 5 with the suction cup in place, or just draw an arrow digitally to the seam you're referring to in step 2. Or call "Step 2" "Important Note" instead of a step.
    David Smith - Reply
    Wow, I'm glad I read this first. I too assumed this step was about inserting the pick, but wasn't sure because it wasn't clearly written that way.
    Agreed with the "important note" idea, along with combining this with step 5 where the context is actually relevant.
    Marco Carag -
  4. Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 1 of 3 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 2 of 3 Google Pixel 5 Motherboard Replacement, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the bottom edge of the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. Google Pixel 5 Motherboard Replacement: step 5, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 5, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 5, image 3 of 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and its bezel frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 5 Motherboard Replacement, Insert an opening pick: step 6, image 3 of 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • If your screen is badly cracked, follow this guide to tape over the cracked screen. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Insert the opening pick into the gap.
    "Insert the opening pick into the gap." NOT the gap under the glass, the second gap... If not you will probably break your screen, at least I did. Especially important if your pixel 5 shipped with the screen gap :(
    Alex Beaven (Nevbox) - Reply
  7. Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 1 of 3 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 2 of 3 Google Pixel 5 Motherboard Replacement, Slice the bottom adhesive: step 7, image 3 of 3
    • Slide the opening pick back and forth along the bottom of the screen to slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  8. Google Pixel 5 Motherboard Replacement, Heat the left edge of the screen: step 8, image 1 of 1
    • Apply a heated iOpener to the left edge of the screen for one minute.
  9. Google Pixel 5 Motherboard Replacement: step 9, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 9, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 9, image 3 of 3
    • Insert another opening pick into the bottom left corner of the screen.
    • Slide the opening pick around the left corner.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable located in the middle of the left edge.
    • Continue to slide the pick up towards the front camera to slice the adhesive on the left edge of the screen.
    • Leave the pick inserted to prevent the adhesive from re-sealing.
    I suggest placing an orientation sticker on the screen so you don't lose track of where that delicate ribbon cable is. I gently bent one, immediately after doing a successful one, resulting in a costly screen replacement. It's important to know that it's incredibly delicate.
    Edward McClung - Reply
  10. Google Pixel 5 Motherboard Replacement: step 10, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 10, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 10, image 3 of 3
    • Insert another opening pick into the top left corner of the screen.
    • Slide the pick around the front camera and across the top edge of the phone.
    • If the adhesive is difficult to slice, apply heat to the area for one minute and try again.
    • Slide the pick to the top right corner of the phone and leave the pick inserted.
  11. Google Pixel 5 Motherboard Replacement: step 11, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 11, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 11, image 3 of 3
    • Insert an opening pick into the bottom right corner of the screen.
    • Slide the pick up to the top right corner to slice the last edge of adhesive.
    • You may need to run an opening pick around the edges again to ensure all the adhesive is cut. It is applied the thickest on the four corners.
  12. Google Pixel 5 Motherboard Replacement, Open up the screen: step 12, image 1 of 2 Google Pixel 5 Motherboard Replacement, Open up the screen: step 12, image 2 of 2
    • Use the opening pick from the top left corner to lift up the left edge of the screen a few millimeters. This will keep the clips from snapping back down into the case.
    • Lift up on the right side of the screen and open up the phone like a book.
    • Do not open the screen more than 90 degrees to prevent damaging the screen flex cable.
  13. Google Pixel 5 Motherboard Replacement, Disconnect the screen: step 13, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the screen: step 13, image 2 of 2
    • Use tweezers to grip the screen connector cover securing the screen flex cable.
    • Push the clip in towards the connector to unlatch it.
    I found it easier to use the spudger here rather than the tweezers (which have sharp ends that could damage something if you happen to slip).
    tristanwaddington - Reply
    some 5a models will have a screw instead of clip , here's a photo https://imgur.com/a/9dZG5pQ
    Daniel Gonzales - Reply
  14. Google Pixel 5 Motherboard Replacement: step 14, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 14, image 2 of 2
    • Remove the screen connector cover.
    • Make sure to keep this component to reinstall it during reassembly.
  15. Google Pixel 5 Motherboard Replacement: step 15, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 15, image 2 of 2
    • Use the tip of the spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage
    The curved ends of the blue iFixit Opening Tool helped me reseat the connector when installing the new screen.
    Jesus no wonder the Chinese factory workers kill themselves, this thing is brutal
    Holy Moly - Reply
    So hard to get this thing reseated to test the screen, even before putting the adheasive round the phone edge to finish the job. What made it particularly hard was that the flex cable on mine seemed very short compared to video's i've seen online.
    Jake Boddington - Reply
  16. Google Pixel 5 Motherboard Replacement, Remove the screen: step 16, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the screen: step 16, image 2 of 2
    • Remove the screen.
    • Use tweezers to pick off the remaining adhesive on the case.
    • If you use isopropyl alcohol to clean the adhesive off the display, be sure to not let it splash onto any unintended components, as this can weaken their adhesive bond.
    • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
    • If your replacement screen's display cable is held down by tape, remove the tape before installation.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Where from we can buy the screen. Thanks
    Ajay Sharma - Reply
    the screen does not fit
    Joel Kelly - Reply
    After reconnecting the screen, is it necessary to remove a screen protector (if installed) for the a proper screen calibration?
    Maxx - Reply
  17. Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the graphite tape: step 17, image 3 of 3
    • Use tweezers to lift up the graphite tape until you are able to grip it with your fingers.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Peel off the graphite tape.
    On reassembly, I missed the graphite tape installation. Will this be an issue?
    Gene Harriman - Reply
  18. Google Pixel 5 Motherboard Replacement: step 18, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 18, image 2 of 2
    • Use tweezers to peel off the graphite pad covering the charging plate cover.
    • If you are able to keep the graphite pad in good condition, you may reapply it during reassembly.
    Would have been much more helpful to start off by saying to be careful removing this piece so you can reuse.
    Also would have been helpful to say that the kit comes with a new one, so don't worry about saving it.
    lupa - Reply
  19. Google Pixel 5 Motherboard Replacement, Remove the charging plate cover: step 19, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T3 Torx driver to remove the two 4.6 mm-long screws securing the charging plate cover to the midframe.
  20. Google Pixel 5 Motherboard Replacement: step 20, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 20, image 2 of 2
    • Use tweezers to remove the charging plate cover.
  21. Google Pixel 5 Motherboard Replacement: step 21, image 1 of 1
    • Use a T3 Torx driver to remove the eight 4.6 mm-long screws securing the midframe.
  22. Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the midframe: step 22, image 3 of 3
    • Use tweezers to lift up the right side of the midframe.
    • Remove the midframe.
    • The spacer at the top of the phone is likely to fall out when you remove the midframe. Remember to save this spacer for reassembly. See pictures in the motherboard replacement guide.
    Removing the midframe may cause a metal-foam spacer above the light sensor to pop out. After placing in the midframe on re-assembly, you can use the tweezers to squeeze the spacer back in between the midframe and the metal divider near the top of the phone.
    Dumpy Sheep - Reply
    There is a picture of this spacer at https://www.ifixit.com/Guide/Google+Pixe.... To replace it, first replace the midframe. Then, before screwing the midframe back down, use the tweezers to pinch the space together, compressing the foam in the middle, and slide it into place.
    soren - Reply
    In step 21 (and step 23) the photo showing the spacer shows the cover over the rear camera and apparently the camera itself removed. But this is not required and nor is it instructed in this guide. Confusing for photo to not match what I'm looking at.
    Gregg Lee - Reply
  23. Google Pixel 5 Motherboard Replacement, Disconnect the battery: step 23, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the battery: step 23, image 2 of 2
    • Use the pointed end of the spudger to pry the battery connector straight up and disconnect it from the motherboard.
  24. Google Pixel 5 Motherboard Replacement, Remove the shouldered screw: step 24, image 1 of 1
    • Use a T3 Torx driver to remove the 4.1 mm shouldered screw.
  25. Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 1 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 2 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the rear cameras: step 25, image 3 of 3
    • Use the spudger to disconnect the two rear camera press connectors from the motherboard.
    • Use your finger to hold down the rear camera assembly and prevent bending the motherboard.
  26. Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove the rear cameras: step 26, image 3 of 3
    • Use tweezers to lift up on the rear camera assembly to remove it from its housing.
    • If your replacement camera module has a plastic spacer, be sure to remove it before you install the module.
    • Make sure the lens surface is smudge and dust free before you install the camera assembly.
  27. Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 1 of 3 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 2 of 3 Google Pixel 5 Motherboard Replacement, Remove adhesive pull tabs: step 27, image 3 of 3
    • Use blunt nose tweezers to grip the black adhesive pull tab located on the top right edge of the battery. Lift the pull tab with the tweezers until you are able to grip it with your fingers.
    • Pull on the pull tab with a slow, steady force at a shallow angle to prevent the pull tab from snapping in the middle.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • If the pull tab breaks prematurely, use tweezers to retrieve the remaining length of adhesive and continue pulling.
    • If you are unable to retrieve it, move on to the next step.
    I found what helped the best, was after grabbing the tab wrapping it around the tip of the spudger, and rolling slowly away, holding it as close as possible to where the tab was. Before I did that since you're pulling so much at once it easily snapped in half. Luckily I could grab a tiny bit of the strip. After wrapping it around the spudger, it no longer broke. The whole strip came off in one piece. Both pieces are complete horizontal pieces and are along the entire width of the battery, from the side you're pulling to the other side of the battery. There's quite a bit there especially since it stretches during this process. You'll feel it suddenly basically give away. ******
    It is very much like the adhesive strips you use to hang items on the wall. When you're removing the hook, you pull at a low angle on that tab and it stretches until it comes off clean. Pull too high and you peel paint. A similar process here, keep it low and roll it slowly on the spudger. It will come away cleanly.
    Jesse - Reply
    Pull very slowly. Once there is enough out to grip with fingers use your fingers . The tweezers concentrated the load in a small contact area with hard edges. more likely to start a tear. Easier to control pull as well. As the tab comes out keep regripping closer to the battery. That takes the load off the part of tab that has already been stretched thin and weakened.
    Gregg Lee - Reply
    "Shallow" is not a very helpful descriptor for the angle, nor do any of the pictures demonstrate what they meant.
    Instead of pulling straight up, try pulling as parallel to your work surface as possible. It's like removing Command hooks.
    lupa - Reply
  28. Google Pixel 5 Motherboard Replacement: step 28, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 28, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 28, image 3 of 3
    • Use the same process to remove the pull tab located at the bottom left edge of the battery.
    • If this tab breaks prematurely and you are not able to retrieve it with tweezers, move on to the next step.
    I had to fish around for this tab. It was not as easy to find as the last.
    lupa - Reply
  29. Google Pixel 5 Motherboard Replacement, Loosen the adhesive: step 29, image 1 of 2 Google Pixel 5 Motherboard Replacement, Loosen the adhesive: step 29, image 2 of 2
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol into the opening of the affected tab.
    This is a frustrating step since I bought the kit thinking I had everything I needed. I don't keep 90% isopropyl alcohol on hand (71% is effective as a disinfectant, where as 90% is not).
    For those who also do not have 90% on hand, I was able to just gently lift the battery out without the alcohol and the graphite under the battery remained in perfect condition and did not tear at all.
    lupa - Reply
  30. Google Pixel 5 Motherboard Replacement: step 30, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 30, image 2 of 2
    • Tilt the phone so that the alcohol flows towards the remaining adhesive.
    • Wait one minute for the adhesive to soften, then proceed to the next step.
    If you're like me, I ended up having a random piece fall out of the phone that I had no idea where it went. After searching I gave up and left it out. However, after looking at the second photo in this step, the one with it tilted fully towards the camera, I found it. Between the index and thumb in the photo, directly in the center of the phone is a thick gray bar. Just to the right of it is a loose piece that might fall out for you. It looks like two thin pieces of metal that sandwich some insulation. You will also notice two tiny tabs bent at an angle on each end only on one side. If that piece does fall out, that's where it goes. Just match the tab angles with this photo and location. I, unfortunately, don't have that piece anymore and am not willing to break through that display adhesive to put it back anyways.
    Jesse - Reply
  31. Google Pixel 5 Motherboard Replacement, Remove the battery: step 31, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the battery: step 31, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Insert an opening pick into the gap long the left side of the battery.
    • Use the opening pick to slice the remaining adhesive at the top and bottom of the battery.
    • Avoid scraping the two flex cables under the battery with your opening pick.
    • This may be difficult as the adhesive is strategically located between the cables and the battery tray. A possible solution is to cut a plastic card to fit between the flex cables and battery tray edge.
    • Do not bend the battery.
    • Avoid the earpiece contact pins located near the top left corner of the battery as you pry up with your opening pick.
    • If you cannot pry the battery up, add a few more drops of isopropyl alcohol to the adhesive. A plastic card can also be helpful during this process.
    This was, by far, the hardest step for me. Pay very much attention to that link "strategically located". It tells you exactly where the toughest adhesive is. I had to use a lot of isopropyl alcohol, a lot of waiting for the adhesive to dissolve, and the thin spudger on only the top and bottom of the battery to pry it out. I did not use the pick.
    I don't think it's worth applying adhesive when putting the battery back in.
    Dumpy Sheep - Reply
    Absolutely agree. More isopropyl alcohol, a lot of waiting is the key.
    Artem Chepurnyi - Reply
    I would recommend applying a little adhesive to the new battery. I didn't apply any and my battery rattles a bit. I wish I had put a small amount of tape in just to keep it in place.
    Elliot - Reply
    Watch how far you push in. The thin cable for the finger print sensor is at the back I snapped it pushing into the glue.
    Kevin McDonagh - Reply
    Try to not use alcohol. Or at least use just a tiny bit without tilting the phone too much. While it worked for me, it leaked into my primary camera lens. Wide camera is okay fortunately, so I can still take photos for important things, and I hope in the next few days alcohol will evaporate. I also tried to put the iOpener on the camera to increase the pressure and move the alcohol to the edges. It kinda worked but photos are still a no go, too blurred
    Emanuele Luciani - Reply
    Just to update who may read this, alcohol fully evaporated after 1 day. I've been very lucky 😅!
    Emanuele Luciani -
  32. Google Pixel 5 Motherboard Replacement: step 32, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 32, image 2 of 2
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Remove your old battery.
    Step 28 battery replacement guide. This is the battery replacement guide - for bad batteries. So why does it say "Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery." This must have been copied from a different guide, that does not involve battery replacement.
    Gregg Lee - Reply
  33. Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 1 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 2 of 3 Google Pixel 5 Motherboard Replacement, Disconnect the press connectors: step 33, image 3 of 3
    • Use the pointed end of a spudger to disconnect the two press connectors by lifting them straight up from the motherboard.
  34. Google Pixel 5 Motherboard Replacement, Remove the motherboard screws: step 34, image 1 of 1
    • Use a T3 Torx driver to remove the two 2.9 mm screws securing the motherboard to the rear case.
  35. Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 1 of 3 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 2 of 3 Google Pixel 5 Motherboard Replacement, Bend the flex cable out of the way: step 35, image 3 of 3
    • Use a spudger to gently fold the flex cable covering the rear case press connector out of the way.
  36. Google Pixel 5 Motherboard Replacement, Disconnect the press connector: step 36, image 1 of 2 Google Pixel 5 Motherboard Replacement, Disconnect the press connector: step 36, image 2 of 2
    • Use the spudger to disconnect the rear case press connector.
  37. Google Pixel 5 Motherboard Replacement, Remove the motherboard: step 37, image 1 of 2 Google Pixel 5 Motherboard Replacement, Remove the motherboard: step 37, image 2 of 2
    • Insert the pointed end of the spudger into the screw holes near the front facing camera.
    • Push the motherboard down towards the bottom of the phone, then lift up to free the top of the motherboard from the rear case.
  38. Google Pixel 5 Motherboard Replacement: step 38, image 1 of 3 Google Pixel 5 Motherboard Replacement: step 38, image 2 of 3 Google Pixel 5 Motherboard Replacement: step 38, image 3 of 3
    • Use your fingers to pull the motherboard up towards the top of the rear case to free the charging port.
    • Do not bend or twist the motherboard.
    • If the motherboard gets caught on the case, use a spudger to go around the edges and loosen it up.
    • Remove the motherboard.
  39. Google Pixel 5 Motherboard Replacement: step 39, image 1 of 2 Google Pixel 5 Motherboard Replacement: step 39, image 2 of 2
    • After removing the motherboard, the top spacer will usually fall out. To replace it, reposition the midframe without screwing it down. Grasp the spacer with the tweezers and compress the interior foam to squeeze it into position. Then screw the midframe into place.
    • Grip the spacer by the body and not by the delicate end tabs.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 other people completed this guide.
Robert Boyd
26,349 Reputation
94 Guides authored
3 Comments
Good day. Please tell me, what is the size of the vibration motor for the pixel 5? I can't find the type of vibro motor anywhere.
Андрей Тарасенко - Reply
Mr. Boyd, where exactly is the proximity sensor inside the Pixel 5 phone?
J. Goodenough - Reply
Any idea on model number for power IC in pixel 5? The technician is saying its Qualcomm PM8996 or PMI 8996 001 Power Management IC. Can somebody please help with my dead pixel 5 please!
Avichal Verma - Reply
Past 24 Hours: 17
Past 7 Days: 100
Past 30 Days: 445
All Time: 14,436
