Google Pixel 4 XL Rear Camera Module Replacement
  1. Google Pixel 4 XL Rear Camera Module Replacement, Remove the SIM card tray: step 1, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Remove the SIM card tray: step 1, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Remove the SIM card tray: step 1, image 3 of 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 XL Rear Camera Module Replacement, Heat the back panel glass: step 2, image 1 of 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    I found 2 minutes works best per side. Great Guide btw, thank you for being a strong leader in the fight for right to repair.
    Dennis - Reply
  3. Google Pixel 4 XL Rear Camera Module Replacement, Apply a suction cup: step 3, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Apply a suction cup: step 3, image 2 of 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 XL Rear Camera Module Replacement, Insert an opening pick: step 4, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Insert an opening pick: step 4, image 2 of 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 XL Rear Camera Module Replacement, Begin to slice the adhesive: step 5, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Begin to slice the adhesive: step 5, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Begin to slice the adhesive: step 5, image 3 of 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 XL Rear Camera Module Replacement, Slice the lefthand-side adhesive: step 6, image 1 of 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 XL Rear Camera Module Replacement: step 7, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 7, image 2 of 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 XL Rear Camera Module Replacement: step 8, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 8, image 2 of 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 XL Rear Camera Module Replacement, Slice righthand-side adhesive: step 9, image 1 of 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 XL Rear Camera Module Replacement: step 10, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 10, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 10, image 3 of 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
    Be careful when slicing the right side's adhesive. The contacts for the wireless charging pad are close to the edge and can easily be bent with the opening pick.
    John G - Reply
  11. Google Pixel 4 XL Rear Camera Module Replacement, Slice the top-side adhesive: step 11, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Slice the top-side adhesive: step 11, image 2 of 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 XL Rear Camera Module Replacement, Lift up the back panel: step 12, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Lift up the back panel: step 12, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Lift up the back panel: step 12, image 3 of 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 XL Rear Camera Module Replacement: step 13, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 13, image 2 of 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    “and test all functions before sealing it up.”
    Pretty sure I wont be sealing this up for a few hours, might be worth removing this part of the sentence as it’s confusing…
    Geoff B - Reply
    Geoff B: These are good instructions. Any technician worth his or her salt will test the device for functionality before sealing it up. That’s why it reads, “During reassembly…and test all functions before sealing it up.” Not confusing if you read and comprehend the full pin.
    Jeana Morales - Reply
    No instructions on how to fit new sticky gasket before assembly. Removing old adhesive was a messy business, I used IPA on a cotton bud and removed as much as possible with flat end of spudger and kitchen paper.
    Malcolm Hall - Reply
  14. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the battery: step 14, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Remove the four T3 Torx screws securing the battery connector shield:
    • One 1.8 mm screw
    • One 4.1 mm screw
    • One 4.4 mm shouldered screw
    • One 4.0 mm shouldered screw
    Anyone know the thread size of the 1.8mm screw mentioned here? Mine went missing, and I need to get a replacement. I've got a bunch of tiny screw kits, but none of them have fit!
    Joseph Sctbunio - Reply
  15. Google Pixel 4 XL Rear Camera Module Replacement: step 15, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 15, image 2 of 2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 XL Rear Camera Module Replacement: step 16, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 16, image 2 of 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    I had the piece from the cable break off inside the connector. How would I go about getting it out
    Dylan DVP - Reply
    What are the 5 copper dots under the battery connector for.
    Brian Davis - Reply
    When you reattach the connector to the motherboard this is a good time to power up and check basic functionality temporarily. Even though it had appeared it was correctly lined, my camera was not functional, in particular the switch button from the rear to the front camera, I was stuck in selfie mode. Then I was getting a message on the screen, possible hardware or software issues. Once I reattached the connecter (several times) until it was correctly inlined, the error went away and I was able to switch from the rear and front cameras.
    bonita pauley - Reply
    That was a good call! Thanks!
    Esther -
  17. Google Pixel 4 XL Rear Camera Module Replacement: step 17, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 17, image 2 of 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the back panel connector: step 18, image 1 of 1
    • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
    Wouldn’t it make more sense to use the same (orange) color circles as the other 4.1mm screw?
    Mark Kanzler - Reply
    Maybe Google did it to avoid exchange in the models where they differ
    Daniele Carminati -
  19. Google Pixel 4 XL Rear Camera Module Replacement: step 19, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 19, image 2 of 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 XL Rear Camera Module Replacement: step 20, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 20, image 2 of 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
    During reassembly, make sure to firmly connect this back panel connector.
    I had to hold the back panel close to the phone so that the connector stays connected, while putting back all the screws.
    Esther - Reply
  21. Google Pixel 4 XL Rear Camera Module Replacement, Remove the back panel: step 21, image 1 of 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
    REASSEMBLY ADHESIVE: This is the step during reassembly that you'll want to set the back glass adhesive strip on (before you reattach ribbons). Set the adhesive strip into the body of the phone with the red tabs down (toward the body of the phone, it will simply rest inside the lip of the phone body). Press the back glass onto the adhesive strip to set the strip onto the back glass, lift the back glass back out of the body of the phone. Next reattach the ribbons, test functions, reattach connector covers, peel red adhesive cover off of the adhesive (on the back glass) then set the back glass into the phone lip. This could have been explained far better but was skipped over and the generic adhesive instructions posted in the comments are useless for this.
    Michael A. Mascaro - Reply
    There are also detailed instructions at answer 742532, "How do I apply new back panel adhesive on a Pixel 4xl?" (sorry it doesn't let me link directly). But it advises adhering the adhesive to the main frame first before the glass. I do notice a slight lip on the main frame on both sides, which seems less forgiving to align with than the glass, so I would imagine doing the frame first would be easier? I haven't done this yet myself, so would be interested in opinions.
    AySz88 - Reply
    Update: it appears the discrepancy is due to a difference between the third-party adhesives and the iFixit "genuine" one. The iFixit one is not mirror symmetric and must be adhered to the glass back first, though it has cutouts that avoid protrusions and facilitate this. The third-party one (I believe) has no such cutouts and thus must go on the frame first.
    However, in trying to follow Michael's instructions, I could not get the adhesive and red tabs off the blue plastic without distorting the adhesive, and had to take the clear side off first. I ended up directly placing the adhesive onto the glass back, without the frame to help align (I posted my method in the above-mentioned answer 742532). The cutouts in the blue plastic seem to have been made with this in mind.
    AySz88 - Reply
  22. Google Pixel 4 XL Rear Camera Module Replacement, Remove the camera connector covers: step 22, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Remove the camera connector covers: step 22, image 2 of 2
    • Gently pry back the battery adhesive pull tab to allow easier access to the screws underneath it.
  23. Google Pixel 4 XL Rear Camera Module Replacement: step 23, image 1 of 1
    • Remove the three T3 Torx screws securing the rear-facing camera connector cover:
    • One 2.7 mm screw
    • One 4.1 mm screw
    • One 4.2 mm screw
  24. Google Pixel 4 XL Rear Camera Module Replacement: step 24, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 24, image 2 of 2
    • Use a pair of tweezers to remove the rear-facing camera connector cover.
  25. Google Pixel 4 XL Rear Camera Module Replacement: step 25, image 1 of 1
    • Remove the three T3 Torx screws securing the front-facing camera connector cover:
    • One 4.1 mm screw
    • One 4.1 mm shouldered screw
  26. Google Pixel 4 XL Rear Camera Module Replacement: step 26, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 26, image 2 of 2
    • Use a pair of tweezers to remove the front-facing camera connector cover.
  27. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the camera and sensor connectors: step 27, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the camera and sensor connectors: step 27, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the camera and sensor connectors: step 27, image 3 of 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  28. Google Pixel 4 XL Rear Camera Module Replacement: step 28, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement: step 28, image 2 of 2
    • Disconnect the additional sensor connector.
    • This cable is secured to the phone with some light adhesive.
  29. Google Pixel 4 XL Rear Camera Module Replacement, Remove the front camera and sensor assembly: step 29, image 1 of 1
    • Remove the three T3 Torx screws securing the front camera and sensor assembly:
    • Two 2.7 mm screws
    • One 3.1 mm screw
  30. Google Pixel 4 XL Rear Camera Module Replacement: step 30, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 30, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 30, image 3 of 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
    Additional Sensor from Step 28 is held down with adhesive. Gently pry up on cable to remove sensor assembly.
    Devon Sherouse - Reply
    After replacing the camera , the phone shows certificate expired for the face unlock. It would be nice to have the how to fix that here.
    [deleted] - Reply
  31. Google Pixel 4 XL Rear Camera Module Replacement, Remove the screws securing the display connector cover: step 31, image 1 of 1
    • Use a T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
  32. Google Pixel 4 XL Rear Camera Module Replacement, Remove the display connector cover: step 32, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Remove the display connector cover: step 32, image 2 of 2
    • Use a pair of tweezers to remove the display connector cover.
  33. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the display connector: step 33, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the display connector: step 33, image 2 of 2
    • Use the flat end of a spudger to disconnect the display connector from the motherboard.
  34. Google Pixel 4 XL Rear Camera Module Replacement, Remove the motherboard screw: step 34, image 1 of 1
    • Use a T3 Torx driver to remove the 2.7 mm screw securing the motherboard to the frame.
  35. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the motherboard press connectors: step 35, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the motherboard press connectors: step 35, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the motherboard press connectors: step 35, image 3 of 3
    • Use the pointed end of a spudger to disconnect the side buttons connector from the motherboard.
    • Disconnect the two rear-facing camera connectors from the motherboard.
    The screw on the top left of the motherboard is out in this picture, but removal is not included in previous steps. It’s still visible in Step 30.
    cbryancan - Reply
    Thank you! Good catch. I’ve added a new step for removing that screw.
    Carsten Frauenheim -
  36. Google Pixel 4 XL Rear Camera Module Replacement: step 36, image 1 of 1
    • Disconnect the earpiece speaker connector from the motherboard.
  37. Google Pixel 4 XL Rear Camera Module Replacement: step 37, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 37, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 37, image 3 of 3
    • Disconnect the two grip sensor connectors from the motherboard.
    • Disconnect the charge port connector from the motherboard.
  38. Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the antennas: step 38, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the antennas: step 38, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement, Disconnect the antennas: step 38, image 3 of 3
    • Use the pointed end of a spudger and pry up gently to unclip the top antenna connector from the motherboard.
    • Disconnect the bottom antenna connector.
  39. Google Pixel 4 XL Rear Camera Module Replacement, Remove the motherboard: step 39, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Remove the motherboard: step 39, image 2 of 2
    • Using a spudger, pivot the top end of the motherboard up and out of the phone's frame.
  40. Google Pixel 4 XL Rear Camera Module Replacement: step 40, image 1 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 40, image 2 of 3 Google Pixel 4 XL Rear Camera Module Replacement: step 40, image 3 of 3
    • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
    • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
    • Completely remove the motherboard.
    • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
    I was able to remove and replace the camera module without completely removing the motherboard from the body. It makes sense to do the disconnections so no cables are broken, but might not be worth completely removing the motherboard.
    cbryancan - Reply
    It seems Face ID is related to the combination of front camera and mainboard, so if possible, keep these together, for example, when switching the housing because of a broken screen.
    cacol - Reply
  41. Google Pixel 4 XL Rear Camera Module Replacement, Remove the rear cameras: step 41, image 1 of 2 Google Pixel 4 XL Rear Camera Module Replacement, Remove the rear cameras: step 41, image 2 of 2
    • Use a pair of tweezers to remove the rear-facing camera module.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
3 other people completed this guide.
Carsten Frauenheim
112,540 Reputation
338 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,718 Guides authored
One Comment
Hi Sir,
I folllowed this instruction to replace my rear camera but when I assembled again, everything works fine but front camera cannot be detected and faceid not working. It show black screen when I flipped from rear to front camera, faceid show “ face enrollment was not completed?
I am carefull person. I flashed many stock firmwares again but it didn't work. Hope to get your help.
Many thanks.
Tan Vo Huu - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 35
All Time: 4,685
