Introduction
Does your Pixel have a broken or cracked screen? Follow this guide to replace it!
The Pixel 3a’s unreinforced display panel is fragile. If you are reusing the screen, be sure to pay special attention to the warnings in the opening procedure.
Take note of the two seams on the phone:
Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
Before you begin prying, note the following areas on the screen:
Screen flex cable: Do not pry deeper than instructed, or you risk damaging this cable.
Adhesive perimeter: Prying beyond the narrow perimeter without angling the pick will damage the display panel.
Place a suction cup near the right edge of the screen.
Pull on the suction cup with strong steady force.
Insert the pick into the gap, no more than 1 mm.
With the pick 1 mm in the gap, pivot the pick upwards to a steep angle.
At this angle, carefully push the pick into the gap about 1/4" (6 mm). The pick should slide in below the OLED panel.
Slide the pick along the right edge, slicing through the adhesive.
Leave a pick in place to prevent the adhesive from resealing.
Slide the pick around the bottom right corner to slice through the adhesive.
Continue slicing along the bottom edge of the phone and around the left corner.
Slice through the left edge of the phone, making sure to properly angle the pick below the OLED panel and insert it in no more than 1/4" (6 mm).
To angle the pick below the OLED panel, insert the point of the pick no more than 1 mm in, angle the pick upwards, and then slowly push the pick in 1/4".
With all of the edges cut, carefully hinge open the right edge of the screen.
Use an opening pick to carefully cut through any remaining adhesive.
With all of the adhesives cut, flip the attached screen glass side down and rest it on top of the phone. The screen flex cable should be loosely arched.
Carefully peel the black tape covering the screen connector bracket.
Remove the two 4.4 mm long T3 screws securing the screen connector bracket.
Remove the screen connector bracket.
Remove the screen.
Carefully compare your replacement screen with your original part. You may need to transfer additional components (such as the speaker mesh) to the new part.
Follow this guide if you are using custom-cut adhesives.
If you are using double-sided tape such as Tesa tape, follow this guide.
