Introduction
Use this guide to replace the worn-out battery in your Google Pixel 2 XL.
Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
If your battery is swollen, take appropriate precautions. Do not heat your phone. If needed, you can use a dropper or syringe to inject isopropyl alcohol (90+%) around the edges of the back cover to weaken the adhesive. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you’re not sure how to proceed.
Step 1 Opening Procedure
Careful: steps 1-12 are sourced from a guide that's marked as in-progress.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
Gently lift the display from the right side of the phone, opening it like a book.
Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
Remove the connector cover.
Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
Insert the point of a spudger into the small hole on the edge of the display connector cover.
Use the spudger to pry the cover out of its recess.
Use the flat edge of a spudger to lift the display cable connector up from its socket.
Remove the display.
Tool used on this step:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
Remove the midframe.
If available, apply some isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
Insert a couple of opening picks or a plastic card along the right edge of the battery.
Apply steady, even pressure to slowly lever the battery up and out of the phone.
Remove the battery.
To install a new battery:
Use tweezers to peel away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
Press the battery firmly into place for 20-30 seconds.
