Introduction
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the USB‑C board (aka charging board or daughterboard) in your Google Pixel 10 Pro XL.
If you're having issues charging your phone or if the port is loose, it may be time to replace the USB‑C board.
Before starting this repair, try cleaning the port and seeing if it fixes your problem—it's possible a dirty port was the issue.
You'll need replacement back glass adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair depends on how accurately the new adhesives are applied and how clean the surfaces are.
Unplug all cables and completely power down your phone.
Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
Heat an iOpener and lay it on the bottom edge of the back glass for two minutes.
Apply a suction handle to the center of the back glass's bottom edge, as close to the edge as possible.
Pull up on the suction handle with strong, steady force until a gap forms between the back glass and frame.
Insert the tip of an opening pick into the gap.
The back glass is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
Slide the opening pick along the bottom edge to separate the adhesive.
Leave the pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
Insert a second pick under the bottom left corner and slide it up the left edge, stopping at the power button.
Leave the pick inserted to prevent the adhesive from re‑sealing.
Insert a third pick under the bottom right corner of the back glass and slide it up the right edge.
Leave the pick inserted under the top right corner.
Insert a fourth pick under the top right corner.
Slide the pick along the top edge and slightly around the top left corner, stopping at the bottom of the camera bump.
Flip the back glass over the left side of the phone and use the suction handle (or a sturdy object) to prop it up.
Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the back glass connector bracket.
Use the point of a spudger to pry up and disconnect the battery and back glass press connectors.
Use a Torx Plus 3IP screwdriver to remove the four 5.0 mm‑long screws securing the motherboard cover.
Use a Torx Plus 3IP screwdriver to remove the seven screws:
Five 5.0 mm‑long screws
Two 4.1 mm‑long screws
Use a spudger to pry up and disconnect the press connector on the top edge of the USB‑C board.
Use your finger to gently lift the cable, so it's out of the way of the board.
Use a Torx Plus 3IP screwdriver to remove the 4.1 mm‑long screw securing the USB‑C board.
Insert the tip of an opening pick under the center of the USB‑C board's top edge, so it's between the board and the metal lip on the frame.
Slide the pick to the left and gently pry up to unclip the board.
Remove the USB‑C board.
Insert the USB‑C board at a slight downward angle, guiding the port into its recess.
With the board in place, press down firmly on the center of the top edge to clip the board in place.
Use your finger to reconnect the USB‑C board press connector, pressing down on one of the short sides first until it clicks into place, then pressing on the other side.
Use a Torx Plus 3IP screwdriver to install the 4.1 mm‑long screw securing the USB‑C board.
Use your finger to press down and reconnect both interconnect cable press connectors.
Use a Torx Plus 3IP screwdriver to install the four 5.0 mm‑long screws securing the motherboard cover.
Before installing new adhesive, all the old adhesive and its residue must be completely removed from the frame.
Use the point of a spudger to remove all the old screen adhesive from the frame. Try to "roll" the adhesive onto itself so it balls up, making it easier to remove.
If you're having trouble removing smaller chunks, apply a single drop of high‑concentration (>90%) isopropyl alcohol and scrape them up with your spudger.
Hold the adhesive above the frame to find its orientation. Use the rear camera cutout in the liner to help visualize how it will lay in the frame.
With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
Once the top edge is properly aligned, gently press down on the top corners to secure the adhesive.
Slowly peel up and remove the large colored liner, gripping it from the cutout near the top edge.
Remove all liners from the underside of the back glass, paying special attention to the front camera cutouts and bottom edge.
Apply a suction handle to the back glass and prop it up on the left side of your phone, so the cable is near its connector.
Use your finger to press down and connect the back glass and battery press connectors.
Use a spudger to press down firmly on the adhesive to secure it to the frame.
Flip the back glass onto the frame and press it firmly into place.
Hold your phone up and squeeze firmly around the perimeter to strengthen the bond.
Congratulations on completing your repair!
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
