Shop the Holiday Gift Guide
Google Nest Doorbell WiFi GWX3T Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
15
Past 7 Days:
94
Past 30 Days:
358
All Time:
1,735
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 45 minutes
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the Google Nest Doorbell (GWX3T) battery is possible, but the process is tricky and delicate. The battery is glued, so take your time and use care to avoid damage. Most of the time and difficulty in this repair comes from removing the heavily glued battery. Be patient and work slowly to avoid damage.
Parts
Tools
    1. Google Nest Doorbell WiFi GWX3T Battery Replacement, Open the housing: step 1, image 1 of 1
      • Remove the two philips 2 screws
      • Remove the two T5 screws
      Ask FixBot
    2. Google Nest Doorbell WiFi GWX3T Battery Replacement, Open the housing: step 2, image 1 of 2 Google Nest Doorbell WiFi GWX3T Battery Replacement, Open the housing: step 2, image 2 of 2
      • Insert a flathead screwdriver into the top edge of the doorbell and gently pry to begin separating the housing.
      Ask FixBot
    3. Google Nest Doorbell WiFi GWX3T Battery Replacement, Disconnect the battery: step 3, image 1 of 2 Google Nest Doorbell WiFi GWX3T Battery Replacement, Disconnect the battery: step 3, image 2 of 2
      • Use a pair of tweezers to carefully disconnect the battery connector from its socket.
      Ask FixBot
    4. Google Nest Doorbell WiFi GWX3T Battery Replacement, Remove the usb-C connector: step 4, image 1 of 2 Google Nest Doorbell WiFi GWX3T Battery Replacement, Remove the usb-C connector: step 4, image 2 of 2
      • Remove the two screws with a T5 Torx driver. Then, use tweezers to carefully lift out the USB-C connector assembly.
      Ask FixBot
    5. Google Nest Doorbell WiFi GWX3T Battery Replacement, Removing the battery: step 5, image 1 of 2 Google Nest Doorbell WiFi GWX3T Battery Replacement, Removing the battery: step 5, image 2 of 2
      • Caution: Lithium-ion batteries are sensitive and can be dangerous if punctured, bent, or overheated. Work slowly, avoid using metal tools directly on the battery. If the battery looks swollen or damaged, stop immediately and handle it with extra care.
      • Apply isopropyl alcohol 99% around the casing to weaken the adhesive. The battery is held with a lot and strong glue, so be patient. Once loosened, gently pry the battery out.
      • Clean the housing with the isopropyl alcohol
      • The glue can get messy and is difficult to clean—work carefully to avoid spreading it.
      Ask FixBot
    6. Google Nest Doorbell WiFi GWX3T Battery Replacement, Put the new battery and reassemble: step 6, image 1 of 1
      • Place a piece of double-sided tape in the battery compartment, then press the new battery firmly into place.
      • To reassemble your device, follow these instructions in reverse order.
      Ask FixBot
2 other people completed this guide.
Author
with
Josserand-Pierre Gay
173 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 94
Past 30 Days: 358
All Time: 1,735
