Introduction
You can't capture every breathtaking moment with a cracked lens! Use this guide to replace a broken or faulty lens!
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
Removing this and attempting to reconnect the connector ribbon will be really difficult when re-assembling. If you are simply replacing the LCD screen I recommend skipping to Step 13.
Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
The threads on the top left screw are different so be sure to take note of which screw is which (although maybe it doesn’t matter that much).
Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
Simply use your PH00 screwdriver to remove the last three screws, and the lens housing is ready to come off.
5 other people completed this guide.
One Comment
Hey, is there any lens to replace the original one you can recommend? I've seen prices from 15 to 80 Euro, basically everyone claiming the same features (170°).
