GoPro Hero LCD Screen Replacement
  1. GoPro Hero LCD Screen Replacement, Casing: step 1, image 1 of 1
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: step 2, image 1 of 1
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: step 3, image 1 of 1
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: step 4, image 1 of 1
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: step 5, image 1 of 1
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: step 6, image 1 of 1
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 GoPro Hero LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - Reply
  8. GoPro Hero LCD Screen Replacement: step 8, image 1 of 1
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: step 9, image 1 of 1
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: step 10, image 1 of 2 GoPro Hero LCD Screen Replacement: step 10, image 2 of 2
    • Separate the LCD screen from the motherboard.
5 other people completed this guide.
River Drake
1,023 Reputation
5 Guides authored
Cal Poly, Team 12-2, Lancaster Spring 2015 Member of Cal Poly, Team 12-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G2
4 Members
18 Guides authored
3 Comments
Where do you buy the replacement lcd
Anthony Volatile - Reply
I can find the screen but is it compatible with the Hero+
Brian Casado - Reply
Past 24 Hours: 6
Past 7 Days: 83
Past 30 Days: 290
All Time: 22,412
