The first step to removing the faceplate is carefully moving the opening tool around the edge.
After loosening the clips on the edge, pull the faceplate off. Be aware that there is double-sided stick tape holding it on (indicated by the red arrow).
Remove the four Phillips #000 screws.
Once the screws are removed and out of the way, gently remove the board. As you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
This sentence runs together and has redundancy: Once the screws are removed and out of the way, gently remove the board and as you lift the board the computer chip (outlined in orange) will separate from the motherboard
Correction: "Once the screws are removed and out of the way, gently remove the board and as you lift it, the computer chip..."
Take your screwdriver with the PH000 Philips head attachment on it and remove the four screws outlined in red.
Just like before, just pull up on the ribbon strip and remove the connector from the motherboard.
"remove the four screws outlined in red" is the instruction, but the picture only reflects three screws circled in red.
"Just like before just pull up on the ribbon strip and remove connector from the motherboard"
Before... when? In a previous guide? If so, there is no reason to believe the reader even looked at a guide before this one. Even if the reader had looked at other guides, which guide is 'before' referencing? Before is not clear.
At the top of the ribbon cable, there is a black clip that needs to be popped up.
Improper structure:
"At the top of the ribbon strip there is a black clip that needs to popped up"
Correction:
...that needs to be popped up
Gently grab the ribbon with the needle nose tweezers and pull down. This will disconnect the ribbon from the connector.
Now, the motherboard can be removed. Due to the USB connector being on the motherboard, the entire board needs to be replaced.
"Now the motherboard can be removed. Due to the USB connector being on the motherboard the entire board needs to be replaced."
How can this be the last step to replacing the charging port? You have not established a relationship between the USB connector and the charging port.
6 other people completed this guide.
The edge of what? You need to be very specific!
Lisa Hagerty - Reply
