Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
On my GoPro 3 Silver the image sensor has Philips screws and the ribbon cable has a piece poking out to the left of the connector shown which is soldered to the board which makes it impossible to remove completely without de-soldering it.
Using the Phillips head bit, remove the silver screw near the top edge of the board.
Separate the LCD assembly by pulling it away. You should have the bare motherboard!
hello , what type of motherboard should buy for this model Hero 3 Silver ? thanks
16 other people completed this guide.
