Use the plastic opening tool to remove the faceplate.
There is some adhesive and clips so be careful and the faceplate should pop right off.
Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
You should now be able to remove the image sensor by simply pulling it.
2 other people completed this guide.
2 Comments
After the sensor has been replaced, does the camera need any catibration?
