Introduction
Use this guide to replace the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Be sure to power off the GoPro before you start disassembly. Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
  • Be sure to power off the GoPro before you start disassembly.
  • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
WPN - Reply
Use the metal spudger to pry around the perimeter of the panel. Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  • Use the metal spudger to pry around the perimeter of the panel.
  • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
Pry around the panel to ensure it is not attached to the device. Move the panel to the side so you can access the internal components.
  • Pry around the panel to ensure it is not attached to the device.
  • Move the panel to the side so you can access the internal components.
  • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
а где можно купить вот этот шлейф соединяющий дисплей и плату.???
Александр «ivkadre» Карпенко - Reply
Locate the battery.
  • Locate the battery.
  • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
  • Be careful of metal contacts on strip, they can be sharp.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Using tweezers, peel off the copper tape on the right side of the battery.
  • Using tweezers, peel off the copper tape on the right side of the battery.
Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro. Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
Use a pair of tweezers to disconnect the battery connector from the motherboard.
  • Use a pair of tweezers to disconnect the battery connector from the motherboard.
  • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
Lift the battery connector straight up.
glenn tanner - Reply
Remove the two 6 mm Phillips #00 screws. Remove the single 4 mm Phillips #000 screws. Remove the single 4 mm Phillips #000 screws.
  • Remove the two 6 mm Phillips #00 screws.
  • Remove the single 4 mm Phillips #000 screws.
Remove the image sensor from the camera.
  • Remove the image sensor from the camera.
  • You do not have to unplug the black box to remove the USB/SD chip.
Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
  • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
  • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
Gently lift the microSD/Micro USB assembly up and out of the device.
  • Gently lift the microSD/Micro USB assembly up and out of the device.
2 other people completed this guide.
Shariyf Mitchell
162 Reputation
2 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2015 Member of USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Members
12 Guides authored
One Comment
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 29
All Time: 1,444
