GoPro Hero+ LCD Image Sensor Replacement
  1. GoPro Hero+ LCD Image Sensor Replacement, Back Panel: step 1, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement, Back Panel: step 1, image 2 of 2
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
  2. GoPro Hero+ LCD Image Sensor Replacement: step 2, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 2, image 2 of 2
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Image Sensor Replacement: step 3, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 3, image 2 of 2
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
  4. GoPro Hero+ LCD Image Sensor Replacement, Battery: step 4, image 1 of 1
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Image Sensor Replacement: step 5, image 1 of 1
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Image Sensor Replacement: step 6, image 1 of 2 GoPro Hero+ LCD Image Sensor Replacement: step 6, image 2 of 2
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Image Sensor Replacement: step 7, image 1 of 1
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
  8. GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 1 of 3 GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 2 of 3 GoPro Hero+ LCD Image Sensor Replacement, MicroSD/Micro USB Port Assembly: step 8, image 3 of 3
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
  9. GoPro Hero+ LCD Image Sensor Replacement: step 9, image 1 of 1
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
  10. GoPro Hero+ LCD Image Sensor Replacement: step 10, image 1 of 1
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
  11. GoPro Hero+ LCD Image Sensor Replacement: step 11, image 1 of 1
    • Gently lift the microSD/Micro USB assembly up and out of the device.
  12. GoPro Hero+ LCD Image Sensor Replacement, Image Sensor: step 12, image 1 of 1
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
Matthew Tinkey
892 Reputation
4 Guides authored
USF Tampa, Team 2-4, Blackwell Fall 2015 Member of USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 1,590
