Introduction
Many of the components of the GoPro HD Hero2 lie on one of the three boards that make up the motherboard assembly. Remove the entire assembly before finding the specific component you're looking for.
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
Lift the speaker out of the rear case with the tip of a spudger.
Remove the rear case.
Hello. GoPro HERO2 there. overheating after doing update. 10-15 minutes after closing. overheating.
You can try put some new heat sink compound under that silver big element (radiator) that you see in step 9 (simply remove 2 screws holding it).
hellfire -
Remove the three screws securing the motherboard assembly to the front case:
Two 10.8 mm Phillips #00 screws.
One 4.8 mm Phillips #00 screw.
8 other people completed this guide.
2 Comments
Where exactly do you buy the replacement boards? I cant find them anywhere..
