GeeksPhone Keon Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
75
All Time:
602
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If your screen is cracked or non-responsive, use this guide to replace the screen.
Tools
    1. GeeksPhone Keon Screen Replacement, Battery: step 1, image 1 of 2 GeeksPhone Keon Screen Replacement, Battery: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Ask FixBot
    2. GeeksPhone Keon Screen Replacement: step 2, image 1 of 1
      • Lift the cover away from the phone.
      Ask FixBot
    3. GeeksPhone Keon Screen Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Ask FixBot
    1. GeeksPhone Keon Screen Replacement, Back Plate: step 4, image 1 of 2 GeeksPhone Keon Screen Replacement, Back Plate: step 4, image 2 of 2
      • Remove the two 5mm T4 screws on the sides of the small orange plate.
      Ask FixBot
    2. GeeksPhone Keon Screen Replacement: step 5, image 1 of 2 GeeksPhone Keon Screen Replacement: step 5, image 2 of 2
      • Gently remove the small orange plate by pulling it down.
      Ask FixBot
    3. GeeksPhone Keon Screen Replacement: step 6, image 1 of 1
      • Remove the following screws securing the back plate to the device:
      • Two silver 2mm T3 screws
      • Five black 3mm T3 screws
      Ask FixBot
    4. GeeksPhone Keon Screen Replacement: step 7, image 1 of 3 GeeksPhone Keon Screen Replacement: step 7, image 2 of 3 GeeksPhone Keon Screen Replacement: step 7, image 3 of 3
      • Slightly lift up the bottom corner of the backplate.
      • Release the four clips on both sides by pulling them away from the device.
      Ask FixBot
    5. GeeksPhone Keon Screen Replacement: step 8, image 1 of 2 GeeksPhone Keon Screen Replacement: step 8, image 2 of 2
      • Lift the backplate away from the device.
      Ask FixBot
    1. GeeksPhone Keon Screen Replacement, Motherboard: step 9, image 1 of 2 GeeksPhone Keon Screen Replacement, Motherboard: step 9, image 2 of 2
      • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
      • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
      • Remove the 2mm T3 screw in the upper left corner of the motherboard.
      Ask FixBot
    2. GeeksPhone Keon Screen Replacement: step 10, image 1 of 1
      • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
      Ask FixBot
    3. GeeksPhone Keon Screen Replacement: step 11, image 1 of 1
      • Remove the motherboard from the device.
      Ask FixBot
    1. GeeksPhone Keon Screen Replacement, Antenna: step 12, image 1 of 1
      • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
      • Unfasten the plastic clamps attached to the antenna.
      Ask FixBot
    2. GeeksPhone Keon Screen Replacement: step 13, image 1 of 3 GeeksPhone Keon Screen Replacement: step 13, image 2 of 3 GeeksPhone Keon Screen Replacement: step 13, image 3 of 3
      • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
      • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
      Ask FixBot
    1. GeeksPhone Keon Screen Replacement, Screen: step 14, image 1 of 2 GeeksPhone Keon Screen Replacement, Screen: step 14, image 2 of 2
      • Use the metal spudger to gently lift up the back of the screen.
      Ask FixBot
    2. GeeksPhone Keon Screen Replacement: step 15, image 1 of 2 GeeksPhone Keon Screen Replacement: step 15, image 2 of 2
      • Continue to lift up the screen until it is loose from the device.
      Ask FixBot
DavidDrash
266 Reputation
1 Guide authored
USF Tampa, Team 3-5, Eyestone Fall 2015 Member of USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 75
All Time: 602
