Introduction
This guide will show the steps required to replace the upper cover, in order to replace a damaged cover or to gain access to the netbook’s internal components.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here. Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
  • Using the Phillips #0 screwdriver, remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back cover, as marked here.
Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph. If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver. Remove the keyboard.
  • Pry off the keyboard by placing your plastic opening tool on the center of the top row of keys, as shown in the photograph.
  • If the plastic opening tool bends or slips, use something sturdier, such as the Phillips #0 screwdriver.
  • Remove the keyboard.
Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage. Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
  • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
  • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
Emily
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 56
