Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
  • The RAM is located under this cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
Emily
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 113
