Introduction
If you have a Phillips #0 screwdriver, you can easily replace the 3G card.
Unlock the tab located in the top left corner of the netbook.
  • Unlock the tab located in the top left corner of the netbook.
  • The red tab indicated that the battery has been properly unlocked.
  • Remove the battery.
  • When working with electronics, it is always wise to remove the power source before taking the device apart.
The 3G card is located under this cover.
  • The 3G card is located under this cover.
  • Use the Phillips #0 screwdriver to remove one (1) 5mm screw.
  • Use the plastic opening tools to lift up the cover.
  • Using the Phillips #0 screwdriver, remove one (1) 5mm screw holding the card in place.
  • Remove the 3G card from the computer by lifting the card up from the bottom.
  • Notice the two wires connected to the card.
  • Gently detach the wires from the card. The metal portions will "pop" off
Lydia Benjock
1,189 Reputation
11 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 491
