Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
A step-by-step guide to replacing the speaker in the Garmin Nuvi 680.
  1. Flip open the antenna on the back of the device.
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Remove the antenna cover.
    • Remove the antenna cover.
  3. The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Insert the pointed end of a spudger into the leftmost slit of the antenna case. Push the spudger to the right.
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables. Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place. Remove the antenna.
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Gently pull the cable for the on/off button straight up to remove it. The two halves of the device may now be separated.
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • These screws are 6.88 mm long
  11. Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged. Use a spudger to lift the edge of the motherboard.
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
  12. Gently unplug the cable for the battery
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
  13. Lift the motherboard out of the outer case.
    • Lift the motherboard out of the outer case.
  14. Use a spudger to gently pry the speaker out of its slot. Remove the speaker.
    • Use a spudger to gently pry the speaker out of its slot.
    • Remove the speaker.
Chris Marzano
968 Reputation
6 Guides authored
Cal Poly, Team 5-22, Amido Winter 2011 Member of Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 3,143
