Introduction
We will remove all of the components from the watch in order to replace the housing. You will need a nylon spudger and Torx T9 screwdriver.
Grab your Garmin watch and flip it over to get a good view of the four screws that connect the straps to the housing.
Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
Good information, but :
- spudger not really needed, nail is enough.
- missing the one regarding the need for a soldering iron ! The old battery needs to be unsoldered and the new one soldered to the inside wiring. Not so difficult but soldering iron needed !
Got a spare battery on eBay (vendor is http://akku-wechsel.de). Delivery was very fast. After replacement I went from 6~8 hours life to 3~4 weeks :) So happy with the upgrade !
Use your Torx T9 screwdriver to remove the one .8mm screw that holds the main board to the watch housing.
This screw is smaller than the .8mm, and cannot be removed with the Torx T9 screwdriver
5 other people completed this guide.
2 Comments
Hi there!
Thanks for the tutorial!
When i reassemble the watch, do i have to put some glue to seal the tiny holes out of the soundboard, or those rubber rings does the job?
I’m just afraid of screwing the waterproof feature of the watch…
Thanks!!
do you know where i can find atmospheric pressure and temperature sensors?
No way is this a two minute, easy to do exercise. The screws connect to the bar. The bar rotates. Once the first screw is out, the second is very difficult to extract because there is no leverage to use when attempting to turn the remaining screw. Even the simplest internet post recommends a vise.
chiphoyt - Reply
