Introduction
The G&G m-14 is actually quite different than the Tokyo Marui m-14 but in many ways this actually makes it MORE compatible with after market parts and upgrades, and it's much easier to disassemble.
The G&G m-14 takes the same barrels as v2 v3 AEG unlike the marui that requires a unique slotted barrel. The G&G also takes standard v2/v3 gears unlike the marui m-14 that once again take model specific gears. These differences are being stated because there is often confusion where people are told to purchase m-14 specific gears and barrels when they can just use and standard parts that are normally referred to as "Marui compatible". Basically what I am trying to say is that the G&G m14 is more "Tokyo Marui compatible" as we have come to know it then the actual Marui m-14. It's a good thing!
The first step as with most AEG's is cyle the AEG on semi-auto twice to set the piston in the rest position and clear the chamber of any bb's.
Then Remove the battery and keep the back hatch open.
To begin the disassembly put the safety to the safe position.
This will allow you to pull on the back of the trigger guard as shown and hinge the the trigger guard out ward.
Next pull downward on the entire trigger mechanism as it will come straight out.
The cool part about this step is it's exactly like the real firearm and it serves the exact same function.
The next thing to do is remove the bolt catch. This will give you access to the small screw behind it which is part of the next step.
Punch out the the pin with either a thin punch or other appropriate tool. Once the pin is partially sticking out you can grab it with pliers.
Careful not to loose track of the spring behind the catch.
Once the gearbox is opened up quickly remove the main spring and spring guide so that nothing goes fly away.
After this point you can remove the gears. Just as in the other guide try not to misplace the shims unless you want to adjust the shimming yourself.
Check out the G&G AEG Shimming Guide Airsoft guide for more shimming info.
This step is going to cover some of the unique parts of the G&GM-14.
The first part people notice is the unique Anti-reversal latch. This piece can be pulled right out. The spring that is attached is almost identical to those found in version 2/3 gearboxes and functions in the same way.
Next part is the selector piece. This part interacts with the selector on the gun and will make your gun go full-auto or semi-auto depending on it's position. if you flip the gearbox over you can actually see how it directly interacts with the cut-off leaver.
It should be left alone but just encase it does need replacement there is a screw on the out side allowing it to be removed.
Lastly there is the trigger switch. This piece is pressed into place and once the spring is detached from the gearbox post, the switch can be pulled out as shown.
6 other people completed this guide.
