Introduction
The G&G CM RK47 is one of the most affordable and reliable AEG's on the market and with this guide it is easy to dissemble as well.
Start by pressing the top cover retainer button and lifting the top cover off of the gun.
Lift the tabs on the small black cap behind the trigger, and then remove the cap.
Pull the wires out from under the tabs on the spring plate that runs along the top of the gearbox.
Carefully remove the spring plate by tapping it gently with a plastic hammer until it slides off the front of the gearbox.
Remove the four remaining gearbox screws with a 2mm hex driver.
Hold down the cylinder with your thumb while prying the gearbox apart from the top.
As you remove the right half of the gearbox, be sure to hold down the cylinder, piston, and spring assembly so that they do not pop out under tension.
Also keep a close eye out for any gear shims that may dislodge themselves as you are taking the gearbox apart.
Slowly lift the spring guide out of the gearbox along with the piston spring.
Remove the entire piston and cylinder assembly with the tappet plate, tappet plate spring, and air nozzle.
Remove the trigger assembly and lift up the wire harness, unhooking the trigger plunger spring in the process.
4 other people completed this guide.
