Introduction
If your speakers are damaged or not working this guide will show you step-by-step instructions on how to replace your speakers
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along the seam of the back case.
Gently slide the plastic opening tool along the entire seam popping the clips free.
Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
