Introduction
This is another protective layer you will need to remove prior to accessing the internal parts of the device.
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along the seam of the back case.
Gently slide the plastic opening tool along the entire seam popping the clips free.
Lift the shield away from the device and remove the fingerprint scanners ribbon from the motherboard.
