Introduction
Use this guide to replace a damaged back case, or open the case to access other components of your camera.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Turn the camera upside down to locate the battery compartment.
Slide the button up to open the compartment.
Slide the orange button up to release the battery.
Use tweezers or a finger nail to peel back the rubber cover on the left handgrip.
Remove the 3.4 mm Phillips screw.
Remove the 3.7 mm screw.
Use tweezers or a fingernail to peel back the rubber cover on the right handgrip.
Remove the 3.2 mm Phillips screw.
Remove the 3.8 mm Phillips screw.
Remove the 2.8 mm Phillips screw.
Remove the four 4.6 mm Phillips screws from the external flash mount.
Use tweezers or two fingers to remove the mount clip.
Slowly pull the back frame away from the camera.
Use tweezers to pull the white and blue ribbon cable out of the connector.
Slowly lift the metal frame away from the motherboard.
Use tweezers to remove the plastic covering the motherboard.
To remove the ribbon cable, flip back the orange lock on the large ZIF connector with the flat end of a spudger.
Remove the back case.
