Fujifilm Instax Mini 8 Infrared Blaster Replacement
  1. Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: step 1, image 1 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: step 1, image 2 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement, Infrared Blaster: step 1, image 3 of 3
    • First, push in the lens and remove the two AA batteries.
  2. Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 2, image 1 of 2 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 2, image 2 of 2
    • Open the rear compartment and remove the film cartridge.
  3. Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 3, image 1 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 3, image 2 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 3, image 3 of 3
    • Remove screws from bottom of camera with a small #00 Phillips Screwdriver. Then remove screws around the camera. Additionally, there are two screws in the battery compartment which also need to be removed.
  4. Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 4, image 1 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 4, image 2 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 4, image 3 of 3
    • Once all screws are removed, gently pry open the front casing with your hands or plastic opening tools carefully. Do note that there will be a spring that attaches the front casing and the main circuit board, so refrain from allowing excess tension on the spring.
  5. Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 5, image 1 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 5, image 2 of 3 Fujifilm Instax Mini 8 Infrared Blaster Replacement: step 5, image 3 of 3
    • Locate the IR blaster, remove the connecting wire ribbon by prying the connector latch open on the motherboard, then sliding it out. Once the wire ribbon is disconnected, the IR blaster can be lifted away from the motherboard.
Boyang Wu
955 Reputation
5 Guides authored
USF Tampa, Team 4-1, Meier Fall 2015 Member of USF Tampa, Team 4-1, Meier Fall 2015
USFT-MEIER-F15S4G1
4 Members
24 Guides authored
2 Comments
Where can I find the replacements (ir blaster)? What is the function of this part. I dropped my camera and the flash won’t turn on and films develop completely black even in broad daylight.
Jenna - Reply
Can that part be pushed back when cleaning it with a qtip? I think I pushed a bit hard but I don’t know. If it’s pushed back a bit will it effect its use?? Please help!
Orange - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 61
All Time: 11,187
