Fujifilm FinePix S1 Back Camera Body Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Fujifilm FinePix S1 Back Camera Body Replacement, Back Camera Body: step 1, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement, Back Camera Body: step 1, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement, Back Camera Body: step 1, image 3 of 3
    • Remove the 7 screws on the perimeter of the camera body.
  2. Fujifilm FinePix S1 Back Camera Body Replacement: step 2, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 2, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 2, image 3 of 3
    • Remove the flash accessory cap.
    • Remove the spacer covering the screws under the flash accessory cap.
  3. Fujifilm FinePix S1 Back Camera Body Replacement: step 3, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 3, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 3, image 3 of 3
    • Remove the 4 screws from the inside of the flash accessory slot.
    • Pull off the flash accessory slot.
  4. Fujifilm FinePix S1 Back Camera Body Replacement: step 4, image 1 of 2 Fujifilm FinePix S1 Back Camera Body Replacement: step 4, image 2 of 2
    • Remove the screw from LCD Screen hinge cover.
    • Remove the LCD Screen hinge cover.
  5. Fujifilm FinePix S1 Back Camera Body Replacement: step 5, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 5, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 5, image 3 of 3
    • Remove the 3 screws located on the LCD screen hinge.
    • Remove the caps from both ends of the LCD screen hinge by lifting them off.
  6. Fujifilm FinePix S1 Back Camera Body Replacement: step 6, image 1 of 1
    • Remove the 2 screws from under the LCD hinge caps.
  7. Fujifilm FinePix S1 Back Camera Body Replacement: step 7, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 7, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 7, image 3 of 3
    • Pry apart the back body from the rest of the camera.
  8. Fujifilm FinePix S1 Back Camera Body Replacement: step 8, image 1 of 2 Fujifilm FinePix S1 Back Camera Body Replacement: step 8, image 2 of 2
    • Carefully pull the back body off of the camera.
    • Make sure to not yank off the connections from the body to the motherboard.
  9. Fujifilm FinePix S1 Back Camera Body Replacement: step 9, image 1 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 9, image 2 of 3 Fujifilm FinePix S1 Back Camera Body Replacement: step 9, image 3 of 3
    • Use a spudger to lift up on the tab, releasing the yellow wire strip.
    • Use a spudger to lift up on the side tab, releasing the blue wire connection.
Brandon Benavente
677 Reputation
6 Guides authored
USF Tampa, Team 3-6, Sullivan Spring 2016 Member of USF Tampa, Team 3-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G6
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
