Fujifilm Camera Instax Mini 25 shutter cable replacement
  1. Fujifilm Camera Instax Mini 25 shutter cable replacement, Remove the right cover: step 1, image 1 of 2 Fujifilm Camera Instax Mini 25 shutter cable replacement, Remove the right cover: step 1, image 2 of 2
    • With your thumb, try to create a slight space between the cover and the body of the camera.
    • Don't use too much force, you just need to create a space for an opening tool.
    • The cover is held on by five clips: two on the front side, two on the back side, and one on the top.
    • Insert an opening tool and unclip the five clips, one after another.
    • Be careful not to lose the gray piece (which is used to open the rear door). It is held in place by a cover.
    • We now have access to two screws.
    • Repeat the same steps on the left side cover of the device.
    • The cover is again attached by five clips: two on the front side, two on the back side, and one on the top.
    • On the right side: unscrew the two 5.4 mm Philips Head screws. They are identical, so you can interchange them during reassembly.
    • On the left side: unscrew the two Philips Head screws. One is 4.4 mm and one is 5.4 mm, so make sure not to mix them up during reassembly.
    • The body of the device is made up of two halves clipped together, one in the front and one in the back. They are held together by 4 clips, two on each side.
    • There are also clips on the underside, but you cannot unclip them. Because of this, you must be careful with the opening tool.
    • The two sides are now separated. You can now access the internal components.
    • To separate the two halves, unlock the rear door.
    • Be careful, the buttons (ON/OFF, shutter) and the plastic part protecting the photo output will fall.
    • Attention! The flash capacitor will be exposed. It is charged automatically every time the drive is turned on. Do not touch it! Wear protective gloves or discharge it to prevent injuring yourself or damaging the camera.
To reassemble your device, follow the instructions in reverse.
Special thanks to these translators:
fr en
100%
EHaga7 is helping us fix the world! Want to contribute?
Start translating ›
Gualter
123 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 20
All Time: 105
