Introduction
Use this guide to remove and replace the motherboard within a Fugoo Style XL.
Using your hand, gently lift the large plastic tab secured to the rubber holding.
After lifting the tab, slide the speaker out of its case.
Remove the 8 screws (4 on each side) that hold the covers that conceal the bass speakers. Remove these 3mm screws using a #2.0 Hex screwdriver.
3 Comments
Where can I purchase a replacement mother board?
Are you allowed to tell us where you found a motherboard? I can not find one anywhere for my fugoo
A repair guy lost my charging board, is there a way I can bypass it? Or Where can I get a replacement?
